Dell Alienware 13 Heart-Sink Assembly Replacement
Giriş
1. adıma gitIn this guide, we will show you how to remove and replace the heart sink assembly.
Neye ihtiyacın var
Bu adımda kullanılan alet:Heavy-Duty Spudger$4.99
Remove the small access panel using a heavy duty spudger.
Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
Using the pull tab, disconnect the solid-state drive cable from the system board.
Remove the screws that secure the solid-state drive assembly to the computer base.
Lift the solid-state drive assembly off the computer base.
Make sure the screws are off the solid-state assembly.
Slide the new solid-state drive into the solid-state drive assembly.
Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
Replace the screws that secure the solid-state drive assembly to the computer base.
Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board
Remove the screws that secure the palm-rest assembly to the computer base.
Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
Turn the computer over and open the display as far as possible.
Using a plastic scribe, pry up along the edges of the palm-rest assembly.
Lift the connector latch and disconnect the power-button board cable from the system board.
Remove the Keyboard.
Remove the power-button board.
Remove the status-light board.
Remove the touchpad.
Replace the touchpad.
Replace the status-light board.
Replace the power-button board.
Replace the keyboard.
Connect the power-button board cable to the system board.
Align the palm-rest assembly on the computer base and snap it into place.
Close the display and turn the computer over.
Replace the screws that secure the palm-rest assembly to the computer base.
Connect the keyboard cable and the keyboard-backlight cable to the system board.
Lift the connector latches and disconnect the touchpad cable and the status-light cable from the power-button board.
Peel the touchpad cable and status-light cable off the keyboard bracket.
Remove the screws that secure the keyboard to the palm-rest assembly.
Slide and lift the keyboard, along with the cables, off the palm-rest assembly.
Align the screw holes on the NEW keyboard with the screw holes on the palm-rest assembly.
Replace the screws that secure the keyboard to the palm-rest assembly.
Align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
Replace the screws that secure the keyboard bracket to the palm-rest assembly.
Adhere the touchpad cable and status-light cable to the keyboard bracket.
Slide the touchpad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
Remove the screw that secures the power-adapter port bracket to the power-adapter port.
Lift the power-adapter port bracket off the power-adapter port.
Release the power-adapter port from the computer base.
Remove the screws that secure the system board to the computer base.
Disconnect the power-adapter port cable and remove the power-adapter port from the system board.
Connect the power-adapter port cable to the system board.
Replace the screws that secure the system board to the computer base.
Connect the speaker cable to the connector on the system board.
Align the screw hole on the power-adapter port bracket with the screw hole on the power-adapter port.
Replace the screw that secures the power-adapter port bracket to the power-adapter port.
Disconnect the fan cables from the connectors on the system board.
Remove the screws that secure the heat-sink assembly to the system board.
Align the screw holes on the NEW heat-sink assembly with the screw holes on the system board.
Replace the screws that secure the heat-sink assembly to the system board.
Connect the fan cables to the connectors on the system board.
