Ana içeriğe geç
Dell Alienware 13 R3 Display Bezel Replacement
Terrence15
Terrence15 ve 2 diğer katkıda bulunanlar
En son November 8, 2019 tarihinde güncellendi
Tahmin yok
Zor
Topluluk-Katkılı Kılavuz
Manzaralı Yol
In this guide, we will show you how to remove and replace the Display Bezel.
Neye ihtiyacın var
  1. Dell Alienware 13 R3 Display Bezel Replacement, Loosen the Screws: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Loosen the five captive screws that secure the base cover to the computer base.
  2. Dell Alienware 13 R3 Display Bezel Replacement, Pry the Base Cover: adım 2, 1 resimden 1.
    • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
  3. Dell Alienware 13 R3 Display Bezel Replacement, Lift the Base Cover: adım 3, 1 resimden 1.
    • Lift the base cover off the computer base.
  4. Dell Alienware 13 R3 Display Bezel Replacement, Disconnect the Battery Cable: adım 4, 1 resimden 1.
    • Using a plastic scribe, disconnect the battery cable from the system board.
    • Press and hold the power button for five seconds to ground the system board.
    • Connect the battery cable to the system board.
  5. Dell Alienware 13 R3 Display Bezel Replacement, Slide the Tabs: adım 7, 1 resimden 1.
    • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
  6. Dell Alienware 13 R3 Display Bezel Replacement, Tighten the Five Captive Screws: adım 8, 1 resimden 1.
    • Tighten the five captive screws that secure the base cover to the computer base.
  7. Dell Alienware 13 R3 Display Bezel Replacement, Align the Notch: adım 9, 1 resimden 1.
    • CAUTION: To avoid damaging the wireless card, do not place any cables under it.
    • Remove the screw (M2x3) that secures the wireless card and bracket to the computer base.
  8. Dell Alienware 13 R3 Display Bezel Replacement, Lift the Wireless-Card Bracket: adım 10, 1 resimden 1.
    • Lift the wireless-card bracket off the wireless card.
  9. Dell Alienware 13 R3 Display Bezel Replacement, Disconnecting the Antenna Cables: adım 11, 1 resimden 1.
    • Disconnect the antenna cables from the wireless card.
    • Align the notch on the wireless card with the tab on the wireless-card slot.
    • Slide the NEW wireless card at an angle into the wireless-card slot.
    • Connect the antenna cables to the wireless card.
  10. Dell Alienware 13 R3 Display Bezel Replacement, Align the Screw Hole: adım 15, 1 resimden 1.
    • Align the screw hole on the wireless-card bracket with the screw hole on the wireless card and the computer base.
  11. Dell Alienware 13 R3 Display Bezel Replacement, Replace the Screw: adım 16, 1 resimden 1.
    • Replace the screw (M2x3) that secures the wireless-card bracket to the wireless card and the computer base.
  12. Dell Alienware 13 R3 Display Bezel Replacement, Remove the Screw: adım 17, 1 resimden 1.
    • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
  13. Dell Alienware 13 R3 Display Bezel Replacement, Lift and Slide the Solid-State Drive: adım 18, 1 resimden 1.
    • Lift and slide the solid-state drive from the solid-state drive slot.
    • Align the notch on the NEW solid-state drive with the tab on the solid-state drive slot and slide the solid-state drive into the solid-state drive slot.
  14. Dell Alienware 13 R3 Display Bezel Replacement, Press the Memory Module: adım 20, 1 resimden 1.
    • Press the memory module down until it clicks into place.
  15. Dell Alienware 13 R3 Display Bezel Replacement, Popping up the Memory Module: adım 21, 1 resimden 1.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  16. Dell Alienware 13 R3 Display Bezel Replacement, Remove the Memory Module: adım 22, 1 resimden 1.
    • Slide and remove the memory module from the memory-module slot.
    • Align the notch on the NEW memory module with the tab on the memory-module slot and slide the memory module firmly into the slot at an angle.
  17. Dell Alienware 13 R3 Display Bezel Replacement, Press the Memory Module Down: adım 24, 1 resimden 1.
  18. Dell Alienware 13 R3 Display Bezel Replacement, Remove the Screws: adım 25, 1 resimden 1.
    • Remove the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
  19. Dell Alienware 13 R3 Display Bezel Replacement, Using a Plastic Scribe: adım 26, 1 resimden 1.
    • Using a plastic scribe, gently release the tabs that secure rear-I/O cover to the computer base.
    • Slide and remove the rear-I/O cover from the computer base.
  20. Dell Alienware 13 R3 Display Bezel Replacement, Sliding the Rear-I/O: adım 28, 1 resimden 1.
    • Slide the NEW rear-I/O cover into the slots on the computer base and snap the rear-I/O cover into place.
    • Replace the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
  21. Dell Alienware 13 R3 Display Bezel Replacement, Remove the Screws: adım 30, 1 resimden 1.
    • Remove the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  22. Dell Alienware 13 R3 Display Bezel Replacement, Remove the Screw: adım 31, 1 resimden 1.
    • Remove the (M2x3) screw that secures the computer base to the palm-rest assembly.
  23. Dell Alienware 13 R3 Display Bezel Replacement, Remove the Two Screws: adım 32, 1 resimden 1.
    • Remove the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  24. Dell Alienware 13 R3 Display Bezel Replacement, Lift the Computer Base: adım 33, 1 resimden 1.
    • Lift the computer base from the palm-rest assembly.
  25. Dell Alienware 13 R3 Display Bezel Replacement, Align the Screw Holes: adım 34, 1 resimden 1.
    • Align the screw holes on the NEW computer base with the screw holes on the palm-rest assembly.
    • Replace the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
    • Replace the (M2x3) screw that secures the computer base to the palm-rest assembly.
    • Replace the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  26. Dell Alienware 13 R3 Display Bezel Replacement, Disconnecting the Coin-Cell Battery: adım 38, 1 resimden 1.
    • CAUTION: Removing the coin-cell battery resets the BIOS setup program’s settings to default. It is recommended that you note the BIOS setup program’s settings before removing the coin-cell battery.
    • Disconnect the coin-cell battery cable from the system board.
  27. Dell Alienware 13 R3 Display Bezel Replacement, Peeling the Coin-Cell Battery: adım 39, 1 resimden 1.
    • Gently peel off the coin-cell battery along with its cable off the palm-rest assembly.
  28. Dell Alienware 13 R3 Display Bezel Replacement, Adhere the Coin-Cell Battery: adım 40, 1 resimden 1.
    • Adhere the NEW coin-cell battery to the palm-rest assembly.
    • Connect the coin-cell battery cable to the system board.
  29. Dell Alienware 13 R3 Display Bezel Replacement, Peeling the Keyboard Connector: adım 42, 1 resimden 1.
  30. Dell Alienware 13 R3 Display Bezel Replacement, Lifting the Battery: adım 43, 1 resimden 1.
    • Lift the battery off the palm-rest assembly.
  31. Dell Alienware 13 R3 Display Bezel Replacement, Placing the New Battery: adım 44, 1 resimden 1.
    • CAUTION: Ensure the keyboard and keyboard-backlit cables are not under the battery.
    • Using the alignment post, place the NEW battery on the palm-rest assembly.
  32. Dell Alienware 13 R3 Display Bezel Replacement, Adhering the Keyboard: adım 45, 1 resimden 1.
    • Adhere the keyboard connector that secures the battery to the palm-rest assembly.
  33. Dell Alienware 13 R3 Display Bezel Replacement, Disconnect the Left-Fan Cable: adım 46, 1 resimden 1.
    • WARNING: The heat sink may become hot during normal operation. Allow sufficient time for the heat sink to cool before you touch it.
    • CAUTION: For maximum cooling of the processor, do not touch the heat transfer areas on the heat sink. The oils in your skin can reduce the heat transfer capability of the thermal grease.
    • Disconnect the left-fan cable from the system board.
  34. Dell Alienware 13 R3 Display Bezel Replacement, Disconnecting the Right-Fan Cable: adım 47, 1 resimden 1.
    • Disconnect the right-fan cable from the system board.
  35. Dell Alienware 13 R3 Display Bezel Replacement, Remove the Seven Screws: adım 48, 1 resimden 1.
    • In sequential order (as indicated on the heat-sink assembly), remove the seven screws (M2x3) that secure the heat-sink assembly to the system board.
    • Lift the heat-sink assembly off the system board.
  36. Dell Alienware 13 R3 Display Bezel Replacement, Align the Screw Holes: adım 50, 1 resimden 1.
    • CAUTION: Incorrect alignment of the heat sink can damage the system board and processor.
    • NOTE: The original thermal grease can be reused if the original system board and fan are reinstalled together. If either the system board or the fan is replaced, use the thermal pad provided in the kit to ensure that thermal conductivity is achieved.
    • Align the screw holes on the NEW heat-sink assembly with the screw holes on the system board.
    • In sequential order (indicated on the heat-sink assembly), replace the seven screws (M2x3) that secure the heat-sink assembly to the system board.
    • Connect the right-fan cable to the respective connector on the system board.
    • Connect the left-fan cable to the respective connector on the system board.
  37. Dell Alienware 13 R3 Display Bezel Replacement, Turn the Computer Over: adım 54, 1 resimden 1.
    • NOTE: Your computer’s Service Tag is stored in the system board. You must enter the Service Tag in the BIOS setup program after you replace the system board.
    • NOTE: Replacing the system board removes any changes you have made to the BIOS using the BIOS setup program. You must make the appropriate changes again after you replace the system board.
    • NOTE: Before disconnecting the cables from the system board, note the location of the connectors so that you can reconnect the cables correctly after you replace the system board.
    • CAUTION: Place the computer on a clean, flat surface.
    • Turn the computer over.
  38. Dell Alienware 13 R3 Display Bezel Replacement, Disconnecting the Logo-Board Cable: adım 55, 1 resimden 1.
    • Disconnect the logo-board cable from the system board.
  39. Dell Alienware 13 R3 Display Bezel Replacement, Disconnecting the Power-Button Board Cable: adım 56, 1 resimden 1.
    • Using the pull-tab, disconnect the power-button board cable from the system board.
  40. Dell Alienware 13 R3 Display Bezel Replacement, Open the Latch: adım 57, 1 resimden 1.
    • Open the latch and disconnect the display cable from the system board.
  41. Dell Alienware 13 R3 Display Bezel Replacement, Turn the Computer Over: adım 58, 1 resimden 1.
  42. Dell Alienware 13 R3 Display Bezel Replacement, Remove the Screw: adım 59, 1 resimden 1.
    • Remove the screw (M2.5x6L) that secures the USB Type-C port bracket to the system board and lift the USB Type-C port bracket off the system board.
    • Disconnect the power-adapter port cable from the system board.
  43. Dell Alienware 13 R3 Display Bezel Replacement, Disconnect the Speaker Cable: adım 61, 1 resimden 1.
    • Disconnect the speaker cable from the system board.
  44. Dell Alienware 13 R3 Display Bezel Replacement, Open the Latch: adım 62, 1 resimden 1.
    • Open the latch and disconnect the keyboard cable from the system board.
  45. Dell Alienware 13 R3 Display Bezel Replacement, Open the Latch: adım 63, 1 resimden 1.
    • Open the latch and disconnect the keyboard-backlight cable from the system board.
  46. Dell Alienware 13 R3 Display Bezel Replacement, Disconnect the Touch-Pad Cable: adım 64, 1 resimden 1.
    • Open the latch and disconnect the touch-pad cable from the system board.
  47. Dell Alienware 13 R3 Display Bezel Replacement, Remove the Screw: adım 65, 1 resimden 1.
  48. Dell Alienware 13 R3 Display Bezel Replacement, Remove the two Screws: adım 66, 1 resimden 1.
    • Remove the two screws (M2.5x6L) that secure the system board to the palm- rest assembly.
  49. Dell Alienware 13 R3 Display Bezel Replacement, Lift the System Board: adım 67, 1 resimden 1.
    • Lift the system board off the palm-rest assembly.
  50. Dell Alienware 13 R3 Display Bezel Replacement, Align the Screw Holes: adım 68, 1 resimden 1.
    • CAUTION: Ensure that no cables are under the system board.
    • Align the screw holes on the NEW system board with the screw holes on the palm- rest assembly.
  51. Dell Alienware 13 R3 Display Bezel Replacement, Replace the Two Screws: adım 69, 1 resimden 1.
    • Replace the two screws (M2.5x6L) that secure the system-board to the palm- rest assembly.
  52. Dell Alienware 13 R3 Display Bezel Replacement, Align the Screw Hole: adım 70, 1 resimden 1.
    • Align the screw hole on the USB Type-C port bracket with the screw hole on the system board on the back and right side of your computer.
  53. Dell Alienware 13 R3 Display Bezel Replacement, Replace the Screw: adım 71, 1 resimden 1.
    • Replace the screw (M2.5x6L) that secures the USB Type-C port bracket to the system board on the back and right side of your computer.
    • Slide the touch-pad cable into the connector on the system board and close the latch to secure the cable.
  54. Dell Alienware 13 R3 Display Bezel Replacement, Sliding the Keyboard-Backlight: adım 73, 1 resimden 1.
    • Slide the keyboard-backlight cable into the connector on the system board and close the latch to secure the cable.
  55. Dell Alienware 13 R3 Display Bezel Replacement, Slide the Keyboard Cable: adım 74, 1 resimden 1.
    • Slide the keyboard cable into the connector on the system board and close the latch to secure the cable.
    • Connect the speaker cable to the system board.
    • Connect the power-adapter port cable to the system board.
  56. Dell Alienware 13 R3 Display Bezel Replacement, Turn the Computer Over: adım 77, 1 resimden 1.
    • Slide the display cable into the connector on the system board and close the latch to secure the cable.
    • Connect the power-button board cable to the system board.
    • Connect the logo-board cable to the system board.
  57. Dell Alienware 13 R3 Display Bezel Replacement, Remove the Antenna Cables: adım 81, 1 resimden 1.
  58. Dell Alienware 13 R3 Display Bezel Replacement, Remove the Logo-Board Cable: adım 82, 1 resimden 1.
    • Remove the logo-board cable from the routing guides on the palm-rest assembly.
  59. Dell Alienware 13 R3 Display Bezel Replacement, Remove the Display Cable: adım 83, 1 resimden 1.
    • Remove the display cable from the routing guides on the palm-rest assembly.
  60. Dell Alienware 13 R3 Display Bezel Replacement, Turn the Computer Over: adım 84, 1 resimden 1.
  61. Dell Alienware 13 R3 Display Bezel Replacement, Remove the Four Screws: adım 85, 1 resimden 1.
    • Remove the four screws (M2.5x6L) that secure the display assembly to the palm-rest assembly.
  62. Dell Alienware 13 R3 Display Bezel Replacement, Lifting the Display Assembly: adım 86, 1 resimden 1.
    • Lift the display assembly off the palm-rest assembly.
  63. Dell Alienware 13 R3 Display Bezel Replacement, Remove the Cables: adım 87, 1 resimden 1.
    • Remove the cables from the routing holes on the palm-rest assembly.
  64. Dell Alienware 13 R3 Display Bezel Replacement, Placing the Display: adım 88, 1 resimden 1.
    • Place the display assembly on a clean, flat surface.
  65. Dell Alienware 13 R3 Display Bezel Replacement, Route the Cables: adım 89, 1 resimden 1.
    • Route the cables through the routing holes on the palm-rest assembly.
  66. Dell Alienware 13 R3 Display Bezel Replacement, Align the Screw Holes: adım 90, 1 resimden 1.
    • Align the screw holes on the display hinges with the screw holes on the palm- rest assembly.
  67. Dell Alienware 13 R3 Display Bezel Replacement, Replace the Four Screws: adım 91, 1 resimden 1.
    • Replace the four screws (M2.5x6L) that secure the display assembly to the palm-rest assembly.
  68. Dell Alienware 13 R3 Display Bezel Replacement, Turn the Computer Over: adım 92, 1 resimden 1.
  69. Dell Alienware 13 R3 Display Bezel Replacement, Route the Logo-Board Cable: adım 93, 1 resimden 1.
    • Route the logo-board cable through the routing guides on the palm-rest assembly.
  70. Dell Alienware 13 R3 Display Bezel Replacement, Route the Antenna Cables: adım 94, 1 resimden 1.
    • Route the antenna cables through the routing guides on the palm-rest assembly.
    • Using your fingertips, carefully pry up the inside edges of the display bezel.
  71. Dell Alienware 13 R3 Display Bezel Replacement, Lift the Display Bezel: adım 96, 1 resimden 1.
    • Carefully lift the display bezel and turn it over.
  72. Dell Alienware 13 R3 Display Bezel Replacement, Disconnect the Alien Head Logo: adım 97, 1 resimden 1.
    • Open the latch and disconnect the alien head logo-board cable from the logo board.
  73. Dell Alienware 13 R3 Display Bezel Replacement, Peeling the Tape: adım 98, 1 resimden 1.
    • Peel off the tape that secures the logo-board cable to the logo board and disconnect the logo-board cable from the logo board.
  74. Dell Alienware 13 R3 Display Bezel Replacement, Lift the Display Bezel: adım 99, 1 resimden 1.
    • Lift the display bezel off the display assembly.
  75. Dell Alienware 13 R3 Display Bezel Replacement, Place the Display Assembly: adım 100, 1 resimden 1.
    • Connect the logo-board cable to the logo board.
  76. Dell Alienware 13 R3 Display Bezel Replacement, Adhering the Tape: adım 102, 1 resimden 1.
    • Adhere the tape that secures the logo-board cable to the logo board.
  77. Dell Alienware 13 R3 Display Bezel Replacement, Slide the Logo Board Cable: adım 103, 1 resimden 1.
    • Slide the alien head logo-board cable into the logo board and close the latch to secure the cable.
    • Carefully turn the display bezel over.
  78. Dell Alienware 13 R3 Display Bezel Replacement, Align the Bezel: adım 105, 1 resimden 1.
    • Align the display bezel with the display back-cover and antenna assembly and gently snap the display bezel into place.
Sonuç
Terrence15
79.549 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 304
