Ana içeriğe geç
Dell Alienware M18x R2 Memory Modules Replacement
Terrence15
Terrence15 ve başka bir katkıda bulunan
En son November 12, 2019 tarihinde güncellendi
7 - 10 dakika
Kolay
Topluluk-Katkılı Kılavuz
In this guide, we will show you how to remove and replace the Memory Modules.
  1. Dell Alienware M18x R2 Memory Modules Replacement, Popping up the Memory Module: adım 1, 3 resimden 1. Dell Alienware M18x R2 Memory Modules Replacement, Popping up the Memory Module: adım 1, 3 resimden 2. Dell Alienware M18x R2 Memory Modules Replacement, Popping up the Memory Module: adım 1, 3 resimden 3.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
    • Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  2. Dell Alienware M18x R2 Memory Modules Replacement, Removing the Memory Module: adım 2, 2 resimden 1. Dell Alienware M18x R2 Memory Modules Replacement, Removing the Memory Module: adım 2, 2 resimden 2.
    • Remove the memory module from the memory-module connector.
  3. Dell Alienware M18x R2 Memory Modules Replacement, Align the Notch: adım 3, 2 resimden 1. Dell Alienware M18x R2 Memory Modules Replacement, Align the Notch: adım 3, 2 resimden 2.
    • NOTE: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a memory module in the upper connector.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  4. Dell Alienware M18x R2 Memory Modules Replacement, Sliding the Memory Module: adım 4, 1 resimden 1.
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
Sonuç
Terrence15
79.555 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 318
