Giriş
You'll find that this will help improve your battery life to factory new! Always be careful when working with a battery.
Neye ihtiyacın var
Use tweezers to pry and remove the center screw cover on the back cover.
Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
6 farklı kişi bu kılavuzu tamamladı.
