Ana içeriğe geç
Dell Inspiron 11-3168 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11-3168 Battery Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 11-3168 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Battery Replacement: adım 2, 3 resimden 1. Dell Inspiron 11-3168 Battery Replacement: adım 2, 3 resimden 2. Dell Inspiron 11-3168 Battery Replacement: adım 2, 3 resimden 3.
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Battery Replacement: adım 3, 2 resimden 1. Dell Inspiron 11-3168 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Battery Replacement: adım 4, 2 resimden 1. Dell Inspiron 11-3168 Battery Replacement: adım 4, 2 resimden 2.
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Battery Replacement: adım 5, 3 resimden 1. Dell Inspiron 11-3168 Battery Replacement: adım 5, 3 resimden 2. Dell Inspiron 11-3168 Battery Replacement: adım 5, 3 resimden 3.
    • Remove the battery.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
4 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Well done with the instructions. AND I just noticed you attend - attended a school in El Dorado? I grew up in Pine Bluff. Your presentation was a big help to me.
Phillip Dennis - Yanıt
Your are welcome Phillip. I am glad you found that repair guide to be helpful.
Matthew Roomsburg - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 936
