Ana içeriğe geç
Dell Inspiron 13-5368 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-5368 Battery Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 13-5368 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Battery Replacement: adım 2, 2 resimden 1. Dell Inspiron 13-5368 Battery Replacement: adım 2, 2 resimden 2.
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Battery Replacement: adım 4, 1 resimden 1.
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Battery Replacement: adım 5, 2 resimden 1. Dell Inspiron 13-5368 Battery Replacement: adım 5, 2 resimden 2.
    • Remove the battery.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
14 farklı kişi bu kılavuzu tamamladı.
Matt Sugrim
1.042 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S14-G6, Boczar Fall 2017 USF Tampa, Team S14-G6, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S14G6
4 Üyeler
13 adet Kılavuz yazıldı
3 Yorum
Awesome, very user friendly instructions. Was not looking forward to taking to computer repair store to replace internal battery. Thank you so much for these instructions.
rdcath - Yanıt
The new battery replacement does not come with a cable to attach to the motherboard. How can I use the cable from the old battery?
BilboBaggins314 - Yanıt
I have this same question^. Can I reuse the cable from the old battery?
Gloria Kolyabin -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 34
Son 30 gün: 154
Her zaman: 24,789
