Ana içeriğe geç
Dell Inspiron 13-7352 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-7352 Battery Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 13-7352 Battery Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 13-7352 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Battery Replacement: adım 2, 2 resimden 1. Dell Inspiron 13-7352 Battery Replacement: adım 2, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Battery Replacement: adım 3, 1 resimden 1.
    • Gently remove the battery from the rest of the device.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 farklı kişi bu kılavuzu tamamladı.
Mikinna Martin
458 İtibar
2 adet Kılavuz yazıldı
Ekip
3 Yorum
Last I looked up for a different model there was a video..
pc2053 - Yanıt
Hello,
My Dell Inspiron 13-7352 won't turn on; I was using it when there was power outage and I totally drained the battery and it went off automatically, after the power came back I charged it the whole night but it still totally doesn't turn on. I tried to long-press the power button but nothing happens. I am 99% sure that the reason was using it on battery until the whole charge was gone. Please help!
jobgondwe - Yanıt
My Dell did the same thing. I followed the above instructions to remove the battery and then put it right back in. Plugged into power and wa-la...it powered up. So simple. Thanks.
pcoladeb - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 24,988
