Giriş
If the Dell Inspiron 13-7353 is experiencing a corrupted battery, short battery life, physical damage, or any problems requiring the battery to be replaced, use the guide below to replace the battery.
Ensure the battery is still experiencing problems before working on the components.
Before working on the device, power down the computer and clear all debris once the back of the device has been opened.
Neye ihtiyacın var
Using the Phillips #0 screwdriver, remove ten 4 mm screws from the back panel.
Lift and remove the back panel.
For optimal performance, after completing this guide, calibrate your newly installed battery.
