Giriş
The hard drive is the main storage for the computer which includes the opperating system, files, photos, and videos. This is often replaced when the drive becomes full.
Neye ihtiyacın var
Slide the CD/DVD drive on the side of the laptop out using your fingers.
Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
Lift the plastic yellow flap on the system board.
Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
This description is incorrect. I juist ruïned the keyboard connector. In my laptop there is no black securing bar. Instead, the white connector from the keyboard needs to come out of the black one on the motherboard. This is done horizontally.
Flip the computer over and open the display.
Pull on the blue tabs to disconnect the palm rest assembly from the computer.
Be sure to release the securing bars on each of the ribbon cables before pulling on the blue tabs (similar to the keyboard ribbon cable in step 11).
Use a J0 Bit screwdriver to remove the two 6 mm Phillips screws securing the battery located near the bottom of the laptop.
Lift up the bottom of the hard drive which is located at the bottom of the laptop.
Gently pull the drive out at an angle using your fingers.
16 farklı kişi bu kılavuzu tamamladı.
5 Yorum
Worked perfectly, right down to the last screw under the memory.
You are a lifesaver! Thank you.
Thanks! These instructions worked very well for me, and I performed my battery and disk upgrades successfully!
This guide was straight forward and gave me the exact step by step instructions! Good job!
Even a dumbass as myself would understand this and follow through. Thank you author!!!
