Ana içeriğe geç
Dell Inspiron 15 5577 Gaming Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 5577 Gaming Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Be sure to power off and unplug your device before you begin your repair.
    • Unscrew the back cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 15 5577 Gaming Battery Replacement: adım 2, 1 resimden 1.
    • Remove the back cover using an opening tool.
  3. Dell Inspiron 15 5577 Gaming Battery Replacement: adım 3, 2 resimden 1. Dell Inspiron 15 5577 Gaming Battery Replacement: adım 3, 2 resimden 2.
    • Use a T8 Torx driver to remove the five screws around the battery.
  4. Dell Inspiron 15 5577 Gaming Battery Replacement: adım 4, 1 resimden 1.
    • Remove the Battery Cable by gently tugging it perpendicular from the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Battery Replacement: adım 5, 1 resimden 1.
    • Pull the battery out of the laptop by prying it away from the laptop. If you're having difficulty removing it, you can also use a plastic opening tool.
Sonuç
Bir başkası bu kılavuzu tamamladı.
[deleted]
346 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Thank you, you guys rock
Random User - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 47
Her zaman: 5,149
