Ana içeriğe geç
Dell Inspiron 15 Optical Drive Replacement
Edward Pacheco
Edward Pacheco ve başka bir katkıda bulunan
En son May 17, 2016 tarihinde güncellendi
10 - 15 dakika
Kolay
Daha iyi giriş
Neye ihtiyacın var
Aletler
  1. Dell Inspiron 15 Optical Drive Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 15 Optical Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 Optical Drive Replacement: adım 2, 1 resimden 1.
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 Optical Drive Replacement, Optical Drive: adım 3, 2 resimden 1. Dell Inspiron 15 Optical Drive Replacement, Optical Drive: adım 3, 2 resimden 2.
    • Remove the 5mm long Phillips #0 screw that is holding the optical drive in place, as pictured.
    • You can now slide the optical disk drive out of the computer.
    • You do not have to remove the base cover or the Hard Drive if you want to remove just the optical drive.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Edward Pacheco
845 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-8, Landers Spring 2016 UMass Dartmouth, Team 5-8, Landers Spring 2016 üyesi
UMASSD-LANDERS-S16S5G8
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 26
Her zaman: 4,843
