Ana içeriğe geç
Dell Inspiron 15-7547 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-7547 Battery Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Battery Replacement: adım 2, 1 resimden 1.
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Battery Replacement, Battery: adım 3, 2 resimden 1. Dell Inspiron 15-7547 Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
  4. Dell Inspiron 15-7547 Battery Replacement: adım 4, 2 resimden 1. Dell Inspiron 15-7547 Battery Replacement: adım 4, 2 resimden 2.
    • Lift the battery out of the case.
  5. Dell Inspiron 15-7547 Battery Replacement: adım 5, 3 resimden 1. Dell Inspiron 15-7547 Battery Replacement: adım 5, 3 resimden 2. Dell Inspiron 15-7547 Battery Replacement: adım 5, 3 resimden 3.
    • Pull the battery cable's pull tab towards the battery to disconnect it from the motherboard.
    • Pull parallel to the motherboard, not straight up.
    • Most of the cable is attached to the case with adhesive, which may cause slight resistance.
    • Remove the battery.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
Bir başkası bu kılavuzu tamamladı.
Claro
591 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 2,030
