Ana içeriğe geç
Dell Inspiron 15-7559 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-7559 Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
  2. Dell Inspiron 15-7559 Battery Replacement: adım 2, 3 resimden 1. Dell Inspiron 15-7559 Battery Replacement: adım 2, 3 resimden 2. Dell Inspiron 15-7559 Battery Replacement: adım 2, 3 resimden 3.
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
  3. Dell Inspiron 15-7559 Battery Replacement: adım 3, 3 resimden 1. Dell Inspiron 15-7559 Battery Replacement: adım 3, 3 resimden 2. Dell Inspiron 15-7559 Battery Replacement: adım 3, 3 resimden 3.
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
  4. Dell Inspiron 15-7559 Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Locate the battery on the bottom left side of the laptop.
  5. Dell Inspiron 15-7559 Battery Replacement: adım 5, 3 resimden 1. Dell Inspiron 15-7559 Battery Replacement: adım 5, 3 resimden 2. Dell Inspiron 15-7559 Battery Replacement: adım 5, 3 resimden 3.
    • Unscrew the 5 x 2mm x 5mm screws, using the T8 Torx screwdriver.
  6. Dell Inspiron 15-7559 Battery Replacement: adım 6, 3 resimden 1. Dell Inspiron 15-7559 Battery Replacement: adım 6, 3 resimden 2. Dell Inspiron 15-7559 Battery Replacement: adım 6, 3 resimden 3.
    • Using the tab above the battery, raise the battery far enough to disconnect the cables attached to it.
    • Using your hand grab the white portion connecting the cables to the battery and disconnect it.
    • Do not pull on the cables directly. This would risk damaging them or tearing them from the device.
  7. Dell Inspiron 15-7559 Battery Replacement: adım 7, 1 resimden 1.
    • Now lift the battery from the device to remove it.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Trenton Greevebiester
1.536 İtibar
6 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S3-G2, Liner Fall 2017 UW Tacoma, Team S3-G2, Liner Fall 2017 üyesi
UWT-LINER-F17S3G2
5 Üyeler
9 adet Kılavuz yazıldı
2 Yorum
Cool, that’s the easy part. How do you tell the UEFI that it’s okay to charge the new battery?
Stefan Bacon - Yanıt
is it ok to replace the 11.4V battery with the 11.1V version?
Payton DePietro - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 77
Her zaman: 16,459
