Ana içeriğe geç
Dell Inspiron 5570 SSD Replacement
Clay Eickemeyer
Clay Eickemeyer ve 2 diğer katkıda bulunanlar
En son July 19, 2024 tarihinde güncellendi
15 - 30 dakika
Orta
Use this guide to replace the SSD in your Dell Inspiron 5570.
Before you perform this repair, back up your existing SSD if possible. If you’re replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Neye ihtiyacın var
Tamir Setleri
Bu kitler, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
  1. Dell Inspiron 5570 SSD Replacement, Unfasten the back cover: adım 1, 2 resimden 1. Dell Inspiron 5570 SSD Replacement, Unfasten the back cover: adım 1, 2 resimden 2.
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips screwdriver to remove the seven screws securing the back cover:
    • Three 5 mm-long screws
    • Four 7.5 mm-long screws
    • Loosen the three captive screws.
  2. Dell Inspiron 5570 SSD Replacement, Unclip the front corners: adım 2, 2 resimden 1. Dell Inspiron 5570 SSD Replacement, Unclip the front corners: adım 2, 2 resimden 2.
    • Flip the laptop upright and open the lid so that the keyboard is exposed.
    • Insert an opening pick between the front right corner of the back cover and the chassis.
    • Pry upward to release the retaining clips holding the cover.
    • You'll hear clicks whenever a clip is released.
    • Repeat this procedure for the opposite corner.
  3. Dell Inspiron 5570 SSD Replacement, Unclip the front edge: adım 3, 2 resimden 1. Dell Inspiron 5570 SSD Replacement, Unclip the front edge: adım 3, 2 resimden 2.
    • Insert an opening pick between the front edge of the back cover and the chassis, near the trackpad.
    • Pry upward to release the clips along the front edge of the laptop.
  4. Dell Inspiron 5570 SSD Replacement, Remove the back cover: adım 4, 3 resimden 1. Dell Inspiron 5570 SSD Replacement, Remove the back cover: adım 4, 3 resimden 2. Dell Inspiron 5570 SSD Replacement, Remove the back cover: adım 4, 3 resimden 3.
    • Close the screen to the laptop and flip it over.
    • Pull the left side of the back cover away from the frame and remove it.
    • If your back cover is stuck to the chassis, use an opening pick to release the clips around the back cover's perimeter.
  5. Dell Inspiron 5570 SSD Replacement, Disconnect the battery: adım 5, 2 resimden 1. Dell Inspiron 5570 SSD Replacement, Disconnect the battery: adım 5, 2 resimden 2.
    • Pull the tab on the head of the battery cable away from the socket to disconnect the battery.
  6. Dell Inspiron 5570 SSD Replacement, Unfasten the SSD cover: adım 6, 2 resimden 1. Dell Inspiron 5570 SSD Replacement, Unfasten the SSD cover: adım 6, 2 resimden 2.
    • Use your Phillips screwdriver to remove the 4 mm-long screw securing the silver SSD shield.
    • Use your Phillips screwdriver to loosen the captive screw.
  7. Dell Inspiron 5570 SSD Replacement, Remove the SSD cover: adım 7, 2 resimden 1. Dell Inspiron 5570 SSD Replacement, Remove the SSD cover: adım 7, 2 resimden 2.
    • Lift the SSD cover straight off the SSD to remove it.
  8. Dell Inspiron 5570 SSD Replacement, Remove the SSD: adım 8, 3 resimden 1. Dell Inspiron 5570 SSD Replacement, Remove the SSD: adım 8, 3 resimden 2. Dell Inspiron 5570 SSD Replacement, Remove the SSD: adım 8, 3 resimden 3.
    • Grip the edges of the SSD near the screw indent.
    • Pull the SSD straight out from its socket and remove it.
    • If it feels stuck, gently wiggle it side to side as you pull.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell Inspiron answers community for help.
3 farklı kişi bu kılavuzu tamamladı.
Clay Eickemeyer
81.958 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.431 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 26
Son 30 gün: 145
Her zaman: 2,649
