Ana içeriğe geç
Dell Latitude 3189 Battery Replacement
Neye ihtiyacın var
  1. Dell Latitude 3189 Battery Replacement, Lower Case: adım 1, 2 resimden 1. Dell Latitude 3189 Battery Replacement, Lower Case: adım 1, 2 resimden 2.
    • Before beginning, power off and unplug the device.
    • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
  2. Dell Latitude 3189 Battery Replacement: adım 2, 3 resimden 1. Dell Latitude 3189 Battery Replacement: adım 2, 3 resimden 2. Dell Latitude 3189 Battery Replacement: adım 2, 3 resimden 3.
    • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
    • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
    • Avoid prying at the ports.
  3. Dell Latitude 3189 Battery Replacement: adım 3, 2 resimden 1. Dell Latitude 3189 Battery Replacement: adım 3, 2 resimden 2.
    • Grip and lift the lower case up and away.
    • If you feel any significant resistance, double check that all of the screws are loosened.
  4. Dell Latitude 3189 Battery Replacement: adım 4, 3 resimden 1. Dell Latitude 3189 Battery Replacement: adım 4, 3 resimden 2. Dell Latitude 3189 Battery Replacement: adım 4, 3 resimden 3.
    • Before performing any operations within the laptop, unplug the battery.
    • Pull the white battery connector directly out of its motherboard port.
    • Do not pull on the wires.
  5. Dell Latitude 3189 Battery Replacement, Battery: adım 5, 2 resimden 1. Dell Latitude 3189 Battery Replacement, Battery: adım 5, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the three 3.2 mm screws that secure the battery.
  6. Dell Latitude 3189 Battery Replacement: adım 6, 2 resimden 1. Dell Latitude 3189 Battery Replacement: adım 6, 2 resimden 2.
    • Grip the battery and lift it up and out of the chassis.
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
Bir başkası bu kılavuzu tamamladı.
Bryan Pratt
601 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 62
