Giriş
If your Dell Latitude 3189 will not hold a charge anymore, you most likely have a dead battery, which requires replacement.
A battery provides power to your laptop. After a number of repeated charge cycles, batteries will slowly degrade. If you notice that your charged battery is draining faster than usual, you should replace your battery.
A charged battery when punctured can be a fire hazard, so before replacing a battery, deplete its charge. If your battery is bulging, proceed with caution.
Make sure to power down your device before you begin.
Neye ihtiyacın var
Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
Use a Phillips #0 screwdriver to remove the three 3.2 mm screws that secure the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
Bir başkası bu kılavuzu tamamladı.
