Ana içeriğe geç
Dell Latitude D610 Fan Replacement
Jordan Barham
Jordan Barham ve 2 diğer katkıda bulunanlar
En son March 21, 2014 tarihinde güncellendi
10 - 15 dakika
Orta
Replacing a defective fan will stop your computer from overheating, preventing damage and increasing the life of your computer.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Dell Latitude D610 Fan Replacement, Battery: adım 1, 2 resimden 1. Dell Latitude D610 Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Dell Latitude D610 Fan Replacement: adım 2, 3 resimden 1. Dell Latitude D610 Fan Replacement: adım 2, 3 resimden 2. Dell Latitude D610 Fan Replacement: adım 2, 3 resimden 3.
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  3. Dell Latitude D610 Fan Replacement: adım 3, 1 resimden 1.
    • Remove the battery from its compartment.
  4. Dell Latitude D610 Fan Replacement, Keyboard: adım 4, 3 resimden 1. Dell Latitude D610 Fan Replacement, Keyboard: adım 4, 3 resimden 2. Dell Latitude D610 Fan Replacement, Keyboard: adım 4, 3 resimden 3.
    • Use an opening tool or flat tool to remove the plastic cover above the keyboard.
  5. Dell Latitude D610 Fan Replacement: adım 5, 2 resimden 1. Dell Latitude D610 Fan Replacement: adım 5, 2 resimden 2.
    • Remove the two 3.9mm Philips #1 screws that are holding the keyboard in place.
  6. Dell Latitude D610 Fan Replacement: adım 6, 2 resimden 1. Dell Latitude D610 Fan Replacement: adım 6, 2 resimden 2.
    • Using an opening tool, carefully release the keyboard from the case.
    • Making sure not to tear or damage the wires still connecting it to the laptop.
  7. Dell Latitude D610 Fan Replacement: adım 7, 3 resimden 1. Dell Latitude D610 Fan Replacement: adım 7, 3 resimden 2. Dell Latitude D610 Fan Replacement: adım 7, 3 resimden 3.
    • Carfully lift the key board.
    • Lift only about 3 - 4 inches so that the wires holding the keyboard do not get damaged.
    • Pull on the blue tab to unplug the keyboard.
  8. Dell Latitude D610 Fan Replacement, Fan: adım 8, 2 resimden 1. Dell Latitude D610 Fan Replacement, Fan: adım 8, 2 resimden 2.
    • Remove the two 3.9mm Philips #1 screws from the case.
  9. Dell Latitude D610 Fan Replacement: adım 9, 2 resimden 1. Dell Latitude D610 Fan Replacement: adım 9, 2 resimden 2.
    • Remove the sixteen 3.9mm Philips #1 screws from the back.
  10. Dell Latitude D610 Fan Replacement: adım 10, 3 resimden 1. Dell Latitude D610 Fan Replacement: adım 10, 3 resimden 2. Dell Latitude D610 Fan Replacement: adım 10, 3 resimden 3.
    • Turn the computer over. Using an opening tool seperate the top cover from the rest of the frame.
    • Do not open the computer too widely or quickly. Doing so will result in damage to the computer.
  11. Dell Latitude D610 Fan Replacement: adım 11, 3 resimden 1. Dell Latitude D610 Fan Replacement: adım 11, 3 resimden 2. Dell Latitude D610 Fan Replacement: adım 11, 3 resimden 3.
    • Remove the 3.9 mm Philips #1 screw.
    • Unplug the fan cable.
    • Lift fan out of compartment to remove the fan.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jordan Barham
459 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-24, Maness Winter 2014 Cal Poly, Team 6-24, Maness Winter 2014 üyesi
CPSU-MANESS-W14S6G24
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 17
Her zaman: 3,346
