Ana içeriğe geç
Dell XPS 13 7390 Battery Replacement
Neye ihtiyacın var
  1. Dell XPS 13 7390 Battery Replacement, Removing the base cover: adım 1, 3 resimden 1. Dell XPS 13 7390 Battery Replacement, Removing the base cover: adım 1, 3 resimden 2. Dell XPS 13 7390 Battery Replacement, Removing the base cover: adım 1, 3 resimden 3.
    • Remove the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly
    • With the computer face-down, open the computer at an angle.
    • Using a plastic scribe, pry the base cover from the palm-rest assembly, starting at the front left and right corners.
    • Moving the base cover from left to right, release the clips securing the base cover to the palm-rest assembly.
    • Lift the base cover from the palm-rest assembly.
  2. Dell XPS 13 7390 Battery Replacement, Remove the old battery: adım 2, 2 resimden 1. Dell XPS 13 7390 Battery Replacement, Remove the old battery: adım 2, 2 resimden 2.
    • Ensure that the battery cable is disconnected from the system board.
    • Remove the four screws (M2x2) that secure the battery to the palm-rest assembly
    • Remove the screw (M1.6x4) that secures the battery to the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • Turn the computer over, open the display, and press the power button for about 5 seconds to ground the computer.
  3. Dell XPS 13 7390 Battery Replacement, Insert the new battery: adım 3, 1 resimden 1.
    • Align the screw holes on the battery with the screw holes on the palm-rest assembly.
    • Replace the four screws (M2x2) that secure the battery to the palm-rest assembly.
    • Replace the screw (M1.6x4) that secures the battery to the palm-rest assembly
  4. Dell XPS 13 7390 Battery Replacement, Reattach base case: adım 4, 2 resimden 1. Dell XPS 13 7390 Battery Replacement, Reattach base case: adım 4, 2 resimden 2.
    • Align the screw holes on the base cover with the screw holes on the palm-rest assembly and slide in the base cover into place.
    • Replace the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly
Sonuç
Congratulations, you’re all done!
8 farklı kişi bu kılavuzu tamamladı.
Max Kletskov
40.307 İtibar
16 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
141 Üyeler
17.895 adet Kılavuz yazıldı
3 Yorum
I have an xps 13 7390 and when I perform step 1 - prying open the base cover - the computer turns on. I searched the internet for how to configure my PC to not automatically power on when the lid opens (even when it's only opened 1/4 of the way it tries to turn on) and my BIOS does not seem to have a Power On - Lid Open on/off option. Any suggestions? Thanks.
Uncle - Yanıt
UPDATE - My XPS 7390 does, in fact, have a LID Power on/off option through the F2 Function. This gets you into BIOS and it was all the way at the bottom of the Power Management option. Apologies.
Uncle - Yanıt
This guide is better and more accurate than Dell’s website. Just replaced the battery DHGH8 (4-cell 52 Wh, 7.6 V) in my XPS 7390 with no problems.
Jacob Wickham - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 124
Son 30 gün: 546
Her zaman: 12,450
