Ana içeriğe geç
Dell XPS 13 9365 2-in-1 Battery Replacement
Neye ihtiyacın var
  1. Dell XPS 13 9365 2-in-1 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Battery Replacement: adım 2, 1 resimden 1.
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Battery Replacement: adım 3, 1 resimden 1.
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Battery Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Battery Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Battery Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Battery Replacement: adım 7, 1 resimden 1.
    • Lift the battery off the palm-rest assembly.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Johnathan Hammond
45.034 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.989 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 24
Son 30 gün: 137
Her zaman: 14,157
