Ana içeriğe geç
Dell XPS 15 9575 Battery Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9575 Battery Replacement, Bottom Cover: adım 1, 3 resimden 1. Dell XPS 15 9575 Battery Replacement, Bottom Cover: adım 1, 3 resimden 2. Dell XPS 15 9575 Battery Replacement, Bottom Cover: adım 1, 3 resimden 3.
    • For your safety, please make sure the device is powered off and the A/C adapter is unplugged.
    • Use your T5 Torx driver to remove all eight 3.2mm hex screws holding down the back panel.
    • Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
  2. Dell XPS 15 9575 Battery Replacement: adım 2, 1 resimden 1.
    • Make sure all screws are removed before you lift the panel to prevent any damage from occurring.
    • Remove the bottom cover from the device when all sides are free.
  3. Dell XPS 15 9575 Battery Replacement, Interconnect Cable: adım 3, 2 resimden 1. Dell XPS 15 9575 Battery Replacement, Interconnect Cable: adım 3, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove all four silver 3.2mm screws fastening the interconnect cable.
  4. Dell XPS 15 9575 Battery Replacement: adım 4, 2 resimden 1. Dell XPS 15 9575 Battery Replacement: adım 4, 2 resimden 2.
    • Carefully wedge the plastic opening pick between the fan and the interconnect cable.
    • If this position does not release the interconnect cable, slide the opening pick along the edge until it is completely free.
    • Remove the interconnect cable.
  5. Dell XPS 15 9575 Battery Replacement: adım 5, 2 resimden 1. Dell XPS 15 9575 Battery Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the nylon tweezers to remove the interconnect pins from each of the circuit boards.
  6. Dell XPS 15 9575 Battery Replacement, Battery: adım 6, 2 resimden 1. Dell XPS 15 9575 Battery Replacement, Battery: adım 6, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove all eight 6.4mm screws from the battery
  7. Dell XPS 15 9575 Battery Replacement: adım 7, 2 resimden 1. Dell XPS 15 9575 Battery Replacement: adım 7, 2 resimden 2.
    • Use a plastic opening pick to pry the black battery cable away from its silver adapter.
    • Hold the pick at 35 degrees from the computer and push towards the battery to remove the cable from its socket.
    • Do not push straight into the battery cable as this could damage the adapter.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
  8. Dell XPS 15 9575 Battery Replacement: adım 8, 2 resimden 1. Dell XPS 15 9575 Battery Replacement: adım 8, 2 resimden 2.
    • Use a plastic opening pick to separate the battery from the device.
    • Lift the battery straight up and remove it when it is completely separated.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Completed and I still have a working laptop, Many thanks for the guide.
See inline comments above for issues I faced as it took me 40 minutes to complete - but I was being very careful.
Mr Mac - Yanıt
I replaced my battery issue free except for when I screw in the bottom plate my trackpad looses its ability to "click". It only comes back when I completely loosen/ remove the bottom plate... Please advise. Thanks!
Matthew Ormiston - Yanıt
I have the exact same issue as Matthew Ormiston, the new Battery seems to be just a bit bigger.
Simon Feldhaus - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 54
Son 30 gün: 175
Her zaman: 12,747
