Giriş
The guide will take you through the steps to remove and replace the complete screen assembly for the Dell XPS 15 9575 laptop.
Issues with the screen should be fairly easy to detect, from flickering or black bars across the screen, to cracks or physical damage. Check out the Dell XPS 15 9575 Troubleshooting Page for more details on when you need to replace your screen.
This guide will replace the entire screen assembly, including the top case, so if your replacement part only includes the LCD you may need to take some additional steps to affix it to the old top case. Should you end up doing these extra steps, you should take some pictures and document the process so that future users can follow along!
Neye ihtiyacın var
Use your T5 Torx driver to remove all eight 3.2mm hex screws holding down the back panel.
Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
Wedge the plastic opening pick in between the aluminum cover and the motherboard.
Gently pull up popping off the cover and revealing the rest of the heat sink.
Use the Phillips #0 screwdriver to remove two 3.2 mm silver screws.
Use the tweezers to remove the grey cover.
Use the tweezers and gently pull straight up on each of the coaxial cables to disconnect them from their specialized brackets.
Reposition the tweezers farther up on the wire and pull forward to remove the wires from the plastic guides that hold the them in place.
Use the Phillips #0 screwdriver to remove the two 3.2 mm black screws holding down the cover.
Now use the tweezers to carefully remove the silver cover from the backboard.
Gently wedge the plastic opening pick in between the display cable and the backboard.
Gently pry up disconnecting the adapter with the display cable from its bracket.
Bir başkası bu kılavuzu tamamladı.
