Giriş
This guide will be helpful if you need to replace any part of the camera that does not have a specific repair guide. To complete this guide, you will need to desolder wires from the motherboard and circuit boards. Learn more about soldering here.
Neye ihtiyacın var
Turn the camera upside down.
Place your thumb on the switch, and slide it towards the center of the camera.
Begin by removing the outside screws using a Phillips #000 Screwdriver:
Remove the three 3.6 mm silver screws located on the bottom of the camera.
Remove all four of the 4.7 mm screws from the sides of the camera.
Remove the four 4.4 mm silver screws at the corners of the lens using a Phillips #000 screwdriver.
10 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
the big question is how to repair the common stuck open flash?
