Ana içeriğe geç
Disassembling Samsung ATIV Smart PC 500T Backplate
Crystal Dinh
Crystal Dinh ve 3 diğer katkıda bulunanlar
En son June 27, 2019 tarihinde güncellendi
8 - 10 dakika
Orta
In order to get to internal parts of your device, you'll need to remove the backplate first. It is safest to power off your device first. Removing the backplate requires some force, so use caution.
Neye ihtiyacın var
Aletler
  1. Disassembling Samsung ATIV Smart PC 500T Backplate, Backplate: adım 1, 2 resimden 1. Disassembling Samsung ATIV Smart PC 500T Backplate, Backplate: adım 1, 2 resimden 2.
    • Remove the stylus from the device.
    • Place the device screen-up on a hard surface, like a table.
  2. Disassembling Samsung ATIV Smart PC 500T Backplate: adım 2, 3 resimden 1. Disassembling Samsung ATIV Smart PC 500T Backplate: adım 2, 3 resimden 2. Disassembling Samsung ATIV Smart PC 500T Backplate: adım 2, 3 resimden 3.
    • Insert a plastic pry tool or opening pick between the glass and plastic case.
    • Work your way around the plastic edge, unclipping the backplate.
    • Once the clips are loosened, remove the backplate. Some force may be necessary.
    • Though you may need to use force, be careful of the pry tool slipping and hurting you!
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Crystal Dinh
1.062 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 6-6, Williams Fall 2015 Baylor, Team 6-6, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S6G6
3 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
Samsung tablet xe500t1c partition missing problem
waheed - Yanıt
Partition do not show
x drive show
waheed - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 39
Her zaman: 4,014
