Ana içeriğe geç
Disassembling iRobot Roomba 551 Bumper
Cody Rhoads
Cody Rhoads ve 3 diğer katkıda bulunanlar
En son March 17, 2014 tarihinde güncellendi
10 - 20 dakika
Orta
This guide explains how to remove the bumper from your Roomba.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Disassembling iRobot Roomba 551 Bumper, Side Brush: adım 1, 1 resimden 1.
    • Place your Roomba upside-down on a hard surface.
  2. Disassembling iRobot Roomba 551 Bumper: adım 2, 1 resimden 1.
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. Disassembling iRobot Roomba 551 Bumper: adım 3, 1 resimden 1.
    • Gently pull upwards on the brush to remove it.
  4. Disassembling iRobot Roomba 551 Bumper, Bottom Plate: adım 4, 1 resimden 1.
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. Disassembling iRobot Roomba 551 Bumper: adım 5, 2 resimden 1. Disassembling iRobot Roomba 551 Bumper: adım 5, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. Disassembling iRobot Roomba 551 Bumper: adım 6, 1 resimden 1.
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. Disassembling iRobot Roomba 551 Bumper, Bumper: adım 7, 3 resimden 1. Disassembling iRobot Roomba 551 Bumper, Bumper: adım 7, 3 resimden 2. Disassembling iRobot Roomba 551 Bumper, Bumper: adım 7, 3 resimden 3.
    • With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
  8. Disassembling iRobot Roomba 551 Bumper: adım 8, 1 resimden 1.
    • Lift the bottom cover and set it to the side.
  9. Disassembling iRobot Roomba 551 Bumper: adım 9, 2 resimden 1. Disassembling iRobot Roomba 551 Bumper: adım 9, 2 resimden 2.
    • Flip the Roomba over, grasp the bumper, and gently lift to remove.
    • The battery is not secured in place once the bottom plate has been removed, and may fall out when the Roomba is turned right-side up.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cody Rhoads
348 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G14
4 Üyeler
19 adet Kılavuz yazıldı
1Rehber Yorum
Mine had a wire leading from the body to the bumper. The bumper end was held on by two small Phillips screws, which I undid to disconnect it (the bit it screws on to falls off the top of the bumper).
When putting it back together, make sure to put it on again the right way round, with the wire towards the front of the roomba (i.e. furthest from the main body), otherwise you will find the wire gets in the way of the bumper working, and you'll have to take it all apart again, like I did!
Nikki Locke - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 2,695
