Ana içeriğe geç
Doss E-GO II Speaker Driver Replacement
Neye ihtiyacın var
  1. Doss E-GO II Speaker Driver Replacement, Speaker Driver: adım 1, 3 resimden 1. Doss E-GO II Speaker Driver Replacement, Speaker Driver: adım 1, 3 resimden 2. Doss E-GO II Speaker Driver Replacement, Speaker Driver: adım 1, 3 resimden 3.
    • Peel the backing off of the speaker.
    • Remove eight 7.9 mm screws using the Phillips #00 screwdriver.
    • Gently pull apart the grille on the sides of the speaker.
  2. Doss E-GO II Speaker Driver Replacement: adım 2, 3 resimden 1. Doss E-GO II Speaker Driver Replacement: adım 2, 3 resimden 2. Doss E-GO II Speaker Driver Replacement: adım 2, 3 resimden 3.
    • Remove four 9.6 mm screws from one of the speaker drivers using the Phillips #00 screwdriver.
    • Gently flip the driver up away from you.
    • Apply a bead of flux. Press the soldering iron tip firmly to melt the solder.
    • If you heat the area for more than 10 seconds, the excessive heat may damage the wires.
    • Repeat for the other speaker driver if needed.
Sonuç
Shyanne Lee
327 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 117
