Ana içeriğe geç
Dragon Touch Y88X Plus Battery Replacement
Neye ihtiyacın var
  1. Dragon Touch Y88X Plus Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the back case using a plastic opening tool or spudger.
    • Start at the corners and work your way around the perimeter of the tablet.
    • Be gentle to avoid damaging the case or any internal components.
  2. Dragon Touch Y88X Plus Battery Replacement: adım 2, 2 resimden 1. Dragon Touch Y88X Plus Battery Replacement: adım 2, 2 resimden 2.
    • Identify the tablet's battery. It is usually a flat, rectangular component connected to the motherboard.
    • Carefully peel the old battery from the adhesive using your iFixit pry tool.
    • Be very cautious not to puncture the battery if yours has expanded . If the battery is swollen, read the article on What to do with a swollen battery for assistance.
  3. Dragon Touch Y88X Plus Battery Replacement: adım 3, 2 resimden 1. Dragon Touch Y88X Plus Battery Replacement: adım 3, 2 resimden 2.
    • Use a soldering iron to disconnect each connector individually from the motherboard.
  4. Dragon Touch Y88X Plus Battery Replacement: adım 4, 1 resimden 1.
    • Remove any adhesive from the battery.
    • Remove the battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bavly Aziz
195 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Petersen Fall 2023 UMass Dartmouth, Team 1-4, Petersen Fall 2023 üyesi
UMASSD-PETERSEN-F23S1G4
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 175
