Ana içeriğe geç
DualSense Controller v2 Motherboard Replacement
Neye ihtiyacın var
  1. DualSense Controller v2 Motherboard Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 1. DualSense Controller v2 Motherboard Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 2.
    • Disconnect and power down the controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller v2 Motherboard Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 1. DualSense Controller v2 Motherboard Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 2. DualSense Controller v2 Motherboard Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 3.
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller v2 Motherboard Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 1. DualSense Controller v2 Motherboard Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 2.
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller v2 Motherboard Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 1. DualSense Controller v2 Motherboard Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 2. DualSense Controller v2 Motherboard Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 3.
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller v2 Motherboard Replacement, Remove the middle trim: adım 5, 3 resimden 1. DualSense Controller v2 Motherboard Replacement, Remove the middle trim: adım 5, 3 resimden 2. DualSense Controller v2 Motherboard Replacement, Remove the middle trim: adım 5, 3 resimden 3.
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
  6. DualSense Controller v2 Motherboard Replacement, Remove the L1 button: adım 6, 3 resimden 1. DualSense Controller v2 Motherboard Replacement, Remove the L1 button: adım 6, 3 resimden 2. DualSense Controller v2 Motherboard Replacement, Remove the L1 button: adım 6, 3 resimden 3.
    • Insert the flat end of a spudger into the gap above the L1 button.
    • Cover the button with your thumb to prevent it from ejecting across the room.
    • Pry the spudger upward to remove the L1 button.
  7. DualSense Controller v2 Motherboard Replacement, Remove the R1 button: adım 7, 3 resimden 1. DualSense Controller v2 Motherboard Replacement, Remove the R1 button: adım 7, 3 resimden 2. DualSense Controller v2 Motherboard Replacement, Remove the R1 button: adım 7, 3 resimden 3.
    • Insert the flat end of a spudger into the gap above the R1 button.
    • Pry the spudger upward to remove the R1 button.
  8. DualSense Controller v2 Motherboard Replacement, Remove the case screws: adım 8, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
  9. DualSense Controller v2 Motherboard Replacement: adım 9, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 6.5 mm screws behind the L1 and R1 buttons.
  10. DualSense Controller v2 Motherboard Replacement, Unclip the rear case: adım 10, 3 resimden 1. DualSense Controller v2 Motherboard Replacement, Unclip the rear case: adım 10, 3 resimden 2. DualSense Controller v2 Motherboard Replacement, Unclip the rear case: adım 10, 3 resimden 3.
    • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
  11. DualSense Controller v2 Motherboard Replacement, Remove the rear case: adım 11, 2 resimden 1. DualSense Controller v2 Motherboard Replacement, Remove the rear case: adım 11, 2 resimden 2.
    • Use your hands to carefully pull the rear case off of the controller.
    • During reassembly, make sure the red and black vibration motor wires are not pinched between the front and rear case.
  12. DualSense Controller v2 Motherboard Replacement, Reposition the battery: adım 12, 2 resimden 1. DualSense Controller v2 Motherboard Replacement, Reposition the battery: adım 12, 2 resimden 2.
    • Lift the battery out of its bracket and reposition it to the right for better access to the battery connector.
    • Don't strain the battery cables.
  13. DualSense Controller v2 Motherboard Replacement, Disconnect the battery: adım 13, 2 resimden 1. DualSense Controller v2 Motherboard Replacement, Disconnect the battery: adım 13, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Don't pull on the wires to disconnect the battery.
  14. DualSense Controller v2 Motherboard Replacement, Remove the battery: adım 14, 1 resimden 1.
    • Remove the battery.
  15. DualSense Controller v2 Motherboard Replacement, Remove the lower microphone: adım 15, 2 resimden 1. DualSense Controller v2 Motherboard Replacement, Remove the lower microphone: adım 15, 2 resimden 2.
    • Use the pointed end of a spudger to remove the lower microphone from its bracket next to the battery.
    • During reassembly, make sure the end of the microphone's ribbon cable is slotted into the bracket.
  16. DualSense Controller v2 Motherboard Replacement: adım 16, 2 resimden 1. DualSense Controller v2 Motherboard Replacement: adım 16, 2 resimden 2.
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
  17. DualSense Controller v2 Motherboard Replacement, Remove the battery bracket: adım 17, 1 resimden 1.
    • Use a Phillips screwdriver to remove the 6.5 mm screw securing the battery bracket.
  18. DualSense Controller v2 Motherboard Replacement: adım 18, 2 resimden 1. DualSense Controller v2 Motherboard Replacement: adım 18, 2 resimden 2.
    • Lift the battery bracket off of the motherboard.
  19. DualSense Controller v2 Motherboard Replacement, Disconnect the right trigger assembly: adım 19, 2 resimden 1. DualSense Controller v2 Motherboard Replacement, Disconnect the right trigger assembly: adım 19, 2 resimden 2.
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers and disconnect it from the motherboard.
    • Use the pull tab to disconnect the cable. Don't pull on the cable itself.
    • Don't completely remove the ribbon cable yet.
  20. DualSense Controller v2 Motherboard Replacement: adım 20, 2 resimden 1. DualSense Controller v2 Motherboard Replacement: adım 20, 2 resimden 2.
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers, and disconnect it from the trigger assembly.
    • Depending on the controller's model, the ribbon cable may block the motherboard from coming loose. If so, remove the cable from the trigger assembly.
  21. DualSense Controller v2 Motherboard Replacement, Disconnect the left trigger assembly: adım 21, 2 resimden 1. DualSense Controller v2 Motherboard Replacement, Disconnect the left trigger assembly: adım 21, 2 resimden 2.
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the motherboard.
  22. DualSense Controller v2 Motherboard Replacement: adım 22, 2 resimden 1. DualSense Controller v2 Motherboard Replacement: adım 22, 2 resimden 2.
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the trigger assembly.
  23. DualSense Controller v2 Motherboard Replacement, Disconnect the upper microphone: adım 23, 2 resimden 1. DualSense Controller v2 Motherboard Replacement, Disconnect the upper microphone: adım 23, 2 resimden 2.
    • Use a pair of tweezers or your fingers to disconnect the upper microphone from the motherboard.
    • If you're not replacing this microphone, don't remove it from the frame.
  24. DualSense Controller v2 Motherboard Replacement, Disconnect the touchpad: adım 24, 2 resimden 1. DualSense Controller v2 Motherboard Replacement, Disconnect the touchpad: adım 24, 2 resimden 2.
    • Use a pair of tweezers or your fingers to disconnect the touchpad cable from the motherboard.
  25. DualSense Controller v2 Motherboard Replacement, Lift out the motherboard: adım 25, 3 resimden 1. DualSense Controller v2 Motherboard Replacement, Lift out the motherboard: adım 25, 3 resimden 2. DualSense Controller v2 Motherboard Replacement, Lift out the motherboard: adım 25, 3 resimden 3.
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • Don't strain the four soldered wires tethering the motherboard to the vibration motors.
  26. DualSense Controller v2 Motherboard Replacement, Desolder the vibration motor wires: adım 26, 3 resimden 1. DualSense Controller v2 Motherboard Replacement, Desolder the vibration motor wires: adım 26, 3 resimden 2. DualSense Controller v2 Motherboard Replacement, Desolder the vibration motor wires: adım 26, 3 resimden 3.
    FixHub | Power Series Smart Soldering Iron
    $79.95
    • Flip the motherboard and midframe over to access the red and black vibration motor wires.
    • Use a soldering iron to disconnect the vibration motor wires from the motherboard.
    • To learn how to solder, or to get some helpful tips and tricks, check out our soldering guide.
    • During reassembly, refer to this photo to ensure the wires are soldered back to their correct positions.
  27. DualSense Controller v2 Motherboard Replacement, Remove the joystick covers: adım 27, 3 resimden 1. DualSense Controller v2 Motherboard Replacement, Remove the joystick covers: adım 27, 3 resimden 2. DualSense Controller v2 Motherboard Replacement, Remove the joystick covers: adım 27, 3 resimden 3.
    • Use your fingers to remove the left and right joystick covers from the motherboard.
  28. DualSense Controller v2 Motherboard Replacement, Remove the speaker: adım 28, 2 resimden 1. DualSense Controller v2 Motherboard Replacement, Remove the speaker: adım 28, 2 resimden 2.
    • Use your fingers to remove the speaker and foam pad from the motherboard.
    • Only the motherboard remains.
    • During reassembly, make sure the gold contacts on the speaker are aligned with the gold contacts on the motherboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
93.055 İtibar
290 adet Kılavuz yazıldı
1Rehber Yorum
"Replacing the motherboard is necessary to resolve joystick drift and charging port failure." Cleaning the joysticks out with compressed air and/or rubbing alcohol can often resolve the drift issue until it needs to be cleaned again. Joystick replacement is an option without total board replacement. Controllers possibly to calibrate at startup and can be reset to calibrate as well https://osgamers.com/frequently-asked-qu...
Charge port failure definitely doesn't require a board replacement. It's the pins are small, but should be manageable with flux.
Allen Millington - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 101
Son 30 gün: 400
Her zaman: 12,000
