Giriş
Is your hair straightener turning off just after a short time of tuning it on, it might be the damage to outer casing. Due to overuse, it usually starts to deteriorate; this may be caused by overuse of device or just wearing out. If the outer casing in your Dyson Corrale HS03 has defects, it will need to be replaced.
In this guide, we'll show you how to safety check if the outer casing has any damage in your Dyson Corrale HS03 hair straightener.
To make sure your Dyson Corrale has a damage to the outer casing. Check out our Troubleshooting page, before beginning to make any repairs.
Before you begin, make sure the hair straightener is turned off, unplugged from the charger, and completely cooled if it was used recently.
Neye ihtiyacın var
Hold the Dyson with the silver safety lock facing you and push it upward.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
