Ana içeriğe geç
Edifier W820NB Plus Drivers Replacement
Neye ihtiyacın var
  1. Edifier W820NB Plus Drivers Replacement, Ear Pads: adım 1, 1 resimden 1.
    • Start with the headphones face up and the earpads visible.
    FixBot'a Sor
    Yorum Ekle
  2. Edifier W820NB Plus Drivers Replacement: adım 2, 2 resimden 1. Edifier W820NB Plus Drivers Replacement: adım 2, 2 resimden 2.
    • Hold the driver housing in one hand and insert an opening tool into the seam between the earpad and driver housing.
    FixBot'a Sor
    Yorum Ekle
  3. Edifier W820NB Plus Drivers Replacement: adım 3, 2 resimden 1. Edifier W820NB Plus Drivers Replacement: adım 3, 2 resimden 2.
    • With your inserted opening tool, pry around the perimeter of the ear pad until it fully releases.
    • Repeat this procedure for the other side if necessary.
    FixBot'a Sor
    Yorum Ekle
  4. Edifier W820NB Plus Drivers Replacement: adım 4, 1 resimden 1.
    • Repeat for the other side if necessary.
    FixBot'a Sor
    Yorum Ekle
  5. Edifier W820NB Plus Drivers Replacement, Drivers: adım 5, 1 resimden 1.
    • Identify the driver you wish to replace.
    • This guide will use the left driver as an example but the same steps can be mirrored when replacing or removing the right driver. The battery is under the left driver, while the motherboard and daughterboard are under the right driver.
    FixBot'a Sor
    Yorum Ekle
  6. Edifier W820NB Plus Drivers Replacement: adım 6, 2 resimden 1. Edifier W820NB Plus Drivers Replacement: adım 6, 2 resimden 2.
    • Remove all five 5 mm Phillips #0 screws that secure the driver assembly.
    FixBot'a Sor
    Yorum Ekle
  7. Edifier W820NB Plus Drivers Replacement: adım 7, 3 resimden 1. Edifier W820NB Plus Drivers Replacement: adım 7, 3 resimden 2. Edifier W820NB Plus Drivers Replacement: adım 7, 3 resimden 3.
    • Note that the wires for the drivers are on the outermost edge. Try to avoid pushing or cutting them when taking the driver out.
    • Insert a Jimmy in the seam between the driver assembly and driver housing.
    • Rotate the Jimmy along the entire perimeter of the innermost edge to pry it out of place.
    FixBot'a Sor
    Yorum Ekle
  8. Edifier W820NB Plus Drivers Replacement: adım 8, 2 resimden 1. Edifier W820NB Plus Drivers Replacement: adım 8, 2 resimden 2.
    • Gently remove the driver assembly from the rest of the headphone, with care not to strain the connected wire.
    FixBot'a Sor
    Yorum Ekle
  9. Edifier W820NB Plus Drivers Replacement: adım 9, 2 resimden 1. Edifier W820NB Plus Drivers Replacement: adım 9, 2 resimden 2.
    • Skip this step if you are completing a battery replacement.
    • Repeat the procedure for the other driver if necessary.
    • Desolder the four driver connections from the motherboard.
    • Remove the driver assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Happy Zhang
438 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-7, Botvin Spring 2025 UMass Dartmouth, Team 2-7, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S2G7
3 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 39
Her zaman: 623
