Ana içeriğe geç
Edifier W820NB Plus Motherboard Replacement
Neye ihtiyacın var
  1. Edifier W820NB Plus Motherboard Replacement, Ear Pads: adım 1, 1 resimden 1.
    • Start with the headphones face up and the earpads visible.
    FixBot'a Sor
    Yorum Ekle
  2. Edifier W820NB Plus Motherboard Replacement: adım 2, 2 resimden 1. Edifier W820NB Plus Motherboard Replacement: adım 2, 2 resimden 2.
    • Hold the driver housing in one hand and insert an opening tool into the seam between the earpad and driver housing.
    FixBot'a Sor
    Yorum Ekle
  3. Edifier W820NB Plus Motherboard Replacement: adım 3, 2 resimden 1. Edifier W820NB Plus Motherboard Replacement: adım 3, 2 resimden 2.
    • With your inserted opening tool, pry around the perimeter of the ear pad until it fully releases.
    • Repeat this procedure for the other side if necessary.
    FixBot'a Sor
    Yorum Ekle
  4. Edifier W820NB Plus Motherboard Replacement: adım 4, 1 resimden 1.
    • Repeat for the other side if necessary.
    FixBot'a Sor
    Yorum Ekle
  5. Edifier W820NB Plus Motherboard Replacement, Drivers: adım 5, 1 resimden 1.
    • Identify the driver you wish to replace.
    • This guide will use the left driver as an example but the same steps can be mirrored when replacing or removing the right driver. The battery is under the left driver, while the motherboard and daughterboard are under the right driver.
    FixBot'a Sor
    Yorum Ekle
  6. Edifier W820NB Plus Motherboard Replacement: adım 6, 2 resimden 1. Edifier W820NB Plus Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove all five 5 mm Phillips #0 screws that secure the driver assembly.
    FixBot'a Sor
    Yorum Ekle
  7. Edifier W820NB Plus Motherboard Replacement: adım 7, 3 resimden 1. Edifier W820NB Plus Motherboard Replacement: adım 7, 3 resimden 2. Edifier W820NB Plus Motherboard Replacement: adım 7, 3 resimden 3.
    • Note that the wires for the drivers are on the outermost edge. Try to avoid pushing or cutting them when taking the driver out.
    • Insert a Jimmy in the seam between the driver assembly and driver housing.
    • Rotate the Jimmy along the entire perimeter of the innermost edge to pry it out of place.
    FixBot'a Sor
    Yorum Ekle
  8. Edifier W820NB Plus Motherboard Replacement: adım 8, 2 resimden 1. Edifier W820NB Plus Motherboard Replacement: adım 8, 2 resimden 2.
    • Gently remove the driver assembly from the rest of the headphone, with care not to strain the connected wire.
    FixBot'a Sor
    Yorum Ekle
  9. Edifier W820NB Plus Motherboard Replacement: adım 9, 2 resimden 1. Edifier W820NB Plus Motherboard Replacement: adım 9, 2 resimden 2.
    • Skip this step if you are completing a battery replacement.
    • Repeat the procedure for the other driver if necessary.
    • Desolder the four driver connections from the motherboard.
    • Remove the driver assembly.
    FixBot'a Sor
    Yorum Ekle
  10. Edifier W820NB Plus Motherboard Replacement, Motherboard: adım 10, 2 resimden 1. Edifier W820NB Plus Motherboard Replacement, Motherboard: adım 10, 2 resimden 2.
    • Peel off the black strip stuck to the top of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  11. Edifier W820NB Plus Motherboard Replacement: adım 11, 3 resimden 1. Edifier W820NB Plus Motherboard Replacement: adım 11, 3 resimden 2. Edifier W820NB Plus Motherboard Replacement: adım 11, 3 resimden 3.
    • Remove the four 2 mm screws that secure the motherboard with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  12. Edifier W820NB Plus Motherboard Replacement: adım 12, 2 resimden 1. Edifier W820NB Plus Motherboard Replacement: adım 12, 2 resimden 2.
    • Pull the motherboard out.
    • Desolder all motherboard connections.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Happy Zhang
438 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-7, Botvin Spring 2025 UMass Dartmouth, Team 2-7, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S2G7
3 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 28
Her zaman: 350
