Ana içeriğe geç
Fairphone 2 Display Assembly Replacement
Tobias Isakeit
Tobias Isakeit ve başka bir katkıda bulunan
En son July 10, 2024 tarihinde güncellendi
5 dakika
Kolay
Replace the Display Assembly of your Fairphone 2.
  1. Fairphone 2 Display Assembly Replacement, Slim Case: adım 1, 3 resimden 1. Fairphone 2 Display Assembly Replacement, Slim Case: adım 1, 3 resimden 2. Fairphone 2 Display Assembly Replacement, Slim Case: adım 1, 3 resimden 3.
    • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
    • Pull up the back part of the slim case to separate the small snap fit connections.
    • Remove the back part of the slim case.
  2. Fairphone 2 Display Assembly Replacement: adım 2, 3 resimden 1. Fairphone 2 Display Assembly Replacement: adım 2, 3 resimden 2. Fairphone 2 Display Assembly Replacement: adım 2, 3 resimden 3.
    • Get in between the front part of the slim case and the phone's body with your thumb nail.
    • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
  3. Fairphone 2 Display Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the front part of the slim case.
  4. Fairphone 2 Display Assembly Replacement, Battery: adım 4, 3 resimden 1. Fairphone 2 Display Assembly Replacement, Battery: adım 4, 3 resimden 2. Fairphone 2 Display Assembly Replacement, Battery: adım 4, 3 resimden 3.
    • Push the battery toward the top of the phone.
    • Pull the battery out away from the phone.
    It isn't necessary to remove the rim if all you are doing is changing the battery. That becomes necessary if you are to proceed farther into the phone.
    It might be good to begin by saying switch the phone off. The Fairphone is for everybody and most will have no experience of disassembling electronic devices.
    Jim Kinnibrugh - Yanıt
  5. Fairphone 2 Display Assembly Replacement, Display Assembly: adım 5, 3 resimden 1. Fairphone 2 Display Assembly Replacement, Display Assembly: adım 5, 3 resimden 2. Fairphone 2 Display Assembly Replacement, Display Assembly: adım 5, 3 resimden 3.
    • After taking out the battery you can unlock the display assembly.
    • Flip the two blue switches to the inner position.
    • Slide the display assembly towards the bottom of the phone.
    Being technically nervous I couldn't do this. I didn't know how much pressure, pull or push was required.
    Roger Halford - Yanıt
    After I'd watched the video my confidence increased!
    It was a bit stiff and not so easy.
    M ichael Cross - Yanıt
    I have not this easy access to the two blue switches. How Can I do that?
    Anne - Yanıt
    Super, nachdem ich’s im Video gesehen habe, war es supereasy, vielen Dank!
    Imke - Yanıt
    You don´t mention taking the rim off the display first. That stymied me completely. Do add that to your otherwise clear and helpful instructions. Best wishes - Walt Patterson
    Walt Patterson - Yanıt
    This guide is based on the old bumper made in one piece. We should update to the sandwich bumper with a top and bottom part.
    Tobias Isakeit -
    I agree. Took a while to figure that one out!
    Jenny White -
    Sorry, I can not slide away the display assembly to change the main camera module. The 2 blue switches seem to be locked. Cristiano, Italy
    Cristiano Gillardi - Yanıt
    I replay to myself: I did it at last! ! But it was very, very, very, very hard!
    Can’t get any movement at all on screen been trying for over an hour and others too ! there is no way to grip it as its so slippery have tried putting as much presure as possible on display by pushing far end of it with thin plastic implement and endless wiggling and pressing of every possible part of lower case no joy ! feels like its attached at mid sides. Elinor Rivers
    Elinor Rivers - Yanıt
    try sliding along the display while applying some pressure two or three times. it worked really easily for me
    Elisa Werner - Yanıt
    I could slide the display case off very easily after watching the video, but when it came to doing the sequence in reverse I was fiddling about for ages trying to ‘slide’ it back on, until I realised this just wasn’t going to work and needed to click it back into place. Posting here in case this is helpful for others.
    Rachel Neat - Yanıt
    • Another possible way of sliding the display assembly open.
    Impossible de déplacer l'écran vers le bas chez moi. Je n'ose pas forcer... c'est normal?
    benbahmedf - Yanıt
    I can not slide the display assembly. Some help?
    Laura Ivorra - Yanıt
    The display sits very tight.
    So you need to gently apply a little force to slide it open the first time.
    It is hard to get a good grip on the two parts for a successful "magic move".
    Tobias Isakeit - Yanıt
    Leider kann ich weder mit "little force" noch mit "much force" das Display nach der Entriegelung bewegen. Wer kann mit mehr Details helfen?
    Christine Heckmann - Yanıt
    It did work for me. Make sure, you have unlocked the blue switches in step 3 (sorry, had to mention that). if you can't get a grip, you might try to lay a ruler or two credit cards on top of each other on a table that is tight at the wall,
    - place the ruler/credit cards on the table and just attaching the wall
    - place the PF2 with the display upside down on the table in front of the ruler/credit cards with the blue switches towards you and the headphone plug attaching the ruler/cards.
    - then gently but with increasing force push your two thumbs towards the top of the main FP2 unit (or use more fingers to push both in the centre as well as on the two edges). make sure you push horizontally and that the ruler is not higher than the border of the display unit (1.5-2 mm).
    (hope i could explain myself in and understandable way! ;-) )
    metaworx - Yanıt
    Thank you a lot ! This worked for me.
    Nicolas Dudermel -
    Thanks, it worked for us as well.
    deRahier -
    great tip! Thanks so much
    Matthew Kelly -
    Really helped! This way finally worked for me. Thanks :)
    Imogen Michel -
    thank you !!
    Claire Hahn -
    Perfect Metaworx, it worked for me as well :)
    siohdk - Yanıt
    Your nails are slightly long? You are lucky. Hold the phone with the screen on your right palm with the blue bits facing your body. Make sure your fingernails are holding the top of the screen. Push the back of the phone with your left hand. It worked for me.
    Askateth - Yanıt
    Mit einer alten Haltekarte für SIM Cards als Hebel habe ich das Display vorsichtig abgeschoben
    Joachim - Yanıt
    Unglaublich fair, dass ich mich mit diesem Kack alleine beschäftige - wenn ich so weitermache, werde ich demnächst die Trümmer meines Fairphones wahrscheinlich durch Ungeschicklichkeit so beschädigen, dass es unbrauchbar ist!
    Ralf Kiefer - Yanıt
  6. Fairphone 2 Display Assembly Replacement: adım 7, 1 resimden 1.
    • Take off the display assembly.
Sonuç
37 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
123.785 İtibar
189 adet Kılavuz yazıldı
Ekip
7 Yorum
Bonjour ! Es-tu bien sûr d'avoir déplacé les deux languettes bleues vers l'intérieur pour libérer l'écran ? Si oui, n'hésite pas à appliquer une certaine force sur l'écran (appuyer et déplacer vers toi).
Oriane Petit - Yanıt
Keine chance das Display zu bewegen. Nach 1h versuchen und allen FP2 Tutorials Videos bin ich immer noch gleichweit. Definitiv Verbesserung würdig. Für weitere Tipps bin ich dankbar, wird es sonst wieder zurück senden :-(
Christian Rapp - Yanıt
Ich habe keine blauen Schalter, ich rede vom FP 1U, ist das korrekt?
Birgit - Yanıt
FP 1U: Ich habe keine blauen Schalter.....
Birgit - Yanıt
The Display seem to be stuck completely, any tips on how to move it?
siohdk - Yanıt
Birgit, denke ich du wollst dieser Link: Fairphone 1 Display Assembly Replacement
adameveleigh - Yanıt
Managed it eventually but the “sliding” bit is really not that easy.
theextraone - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 21
Her zaman: 17,724
