Ana içeriğe geç
Fairphone 3 Bottom Module Replacement
Neye ihtiyacın var
  1. Fairphone 3 Bottom Module Replacement, Back Cover: adım 1, 2 resimden 1. Fairphone 3 Bottom Module Replacement, Back Cover: adım 1, 2 resimden 2.
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
    FixBot'a Sor
    Yorum Ekle
  2. Fairphone 3 Bottom Module Replacement: adım 2, 3 resimden 1. Fairphone 3 Bottom Module Replacement: adım 2, 3 resimden 2. Fairphone 3 Bottom Module Replacement: adım 2, 3 resimden 3.
    • Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Fairphone 3 Bottom Module Replacement, Battery: adım 3, 2 resimden 1. Fairphone 3 Bottom Module Replacement, Battery: adım 3, 2 resimden 2.
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lever the battery up until you can get a good grip.
    FixBot'a Sor
    Yorum Ekle
  4. Fairphone 3 Bottom Module Replacement: adım 4, 2 resimden 1. Fairphone 3 Bottom Module Replacement: adım 4, 2 resimden 2.
    • Lift the battery out of its recess and remove it.
    FixBot'a Sor
    Yorum Ekle
  5. Fairphone 3 Bottom Module Replacement, Display Assembly: adım 5, 1 resimden 1.
    • Whenever a Phillips #00 screw is mentioned you can also unfasten it with a size #0 bit/screwdriver.
    • Remove the thirteen Phillips #00 screws (4 mm length).
    FixBot'a Sor
    Yorum Ekle
  6. Fairphone 3 Bottom Module Replacement: adım 6, 3 resimden 1. Fairphone 3 Bottom Module Replacement: adım 6, 3 resimden 2. Fairphone 3 Bottom Module Replacement: adım 6, 3 resimden 3.
    • Make sure to insert the opening pick between the midframe and the display module and not into the small gap next to the screen. Otherwise you're going to pry up the screen instead of the whole display module.
    • Insert an opening pick between the midframe and the display module on the right edge of the phone.
    • Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
    FixBot'a Sor
    Yorum Ekle
  7. Fairphone 3 Bottom Module Replacement: adım 7, 2 resimden 1. Fairphone 3 Bottom Module Replacement: adım 7, 2 resimden 2.
    • Slide the opening pick around the bottom right corner and use it to disengage the plastic clamps at the bottom of the display module.
    FixBot'a Sor
    Yorum Ekle
  8. Fairphone 3 Bottom Module Replacement: adım 8, 2 resimden 1. Fairphone 3 Bottom Module Replacement: adım 8, 2 resimden 2.
    • Slide the opening pick along the left side to pry the display module up.
    • The display module should pop out of the midframe during this process. In case it doesn’t, check for remaining clamps you might have missed.
    FixBot'a Sor
    Yorum Ekle
  9. Fairphone 3 Bottom Module Replacement: adım 9, 2 resimden 1. Fairphone 3 Bottom Module Replacement: adım 9, 2 resimden 2.
    • Remove the display assembly.
    • To reinstall the display-module press it into place on all sides until you can hear a snap from the plastic clamps to make sure it sits flush with the frame.
    • If you install a new display: The new display module comes with a white plastic cover held by 2 screws over the processor and the connectors. This needs to be taken off.
    FixBot'a Sor
    Yorum Ekle
  10. Fairphone 3 Bottom Module Replacement, Bottom Module: adım 10, 1 resimden 1.
    • Remove the four 4.1mm-longPhillips #00 screws.
    FixBot'a Sor
    Yorum Ekle
  11. Fairphone 3 Bottom Module Replacement: adım 11, 2 resimden 1. Fairphone 3 Bottom Module Replacement: adım 11, 2 resimden 2.
    • Use a spudger to pry up and disconnect the bottom module connecting cable.
    FixBot'a Sor
    Yorum Ekle
  12. Fairphone 3 Bottom Module Replacement: adım 12, 2 resimden 1. Fairphone 3 Bottom Module Replacement: adım 12, 2 resimden 2.
    • Use your fingers to remove the bottom module.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
44 farklı kişi bu kılavuzu tamamladı.
Adriana Zwink
67.148 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
25.946 adet Kılavuz yazıldı
14Kılavuz Yorumları
Spitze, jetzt lädt mein Fairphone 3 wieder tadellos. Tolle Anleitung!!!
Petra Breit - Yanıt Paylaş
Super, das freut uns!
Adriana Zwink - Yanıt Paylaş
Thanks for the guide, it was very helpful. However, I'm pretty sure we don't need to remove so many screws on Step 5.
I for one had a hard time removing one, and I left it in place, and I could achieve the repair without any problem.
I think only the 6 screws on the very outside edge, that correspond with the screen's locations for the screws.
mll - Yanıt Paylaş
Hello @mll, thank you for sharing your experience with us! We're glad that the repair worked out. I've rechecked the display and the phone assembly. All screws should be removed to make sure not to damage components of the phone. Feel free to check Fairphone's video on replacing the display unit: https://www.youtube.com/watch?v=hG6OVPTn...
@adrianazwink , you are right indeed, and I stand corrected.
mll - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 33
Son 30 gün: 210
Her zaman: 22,634
