Ana içeriğe geç
Fairphone 3 Speaker Module Replacement
Neye ihtiyacın var
  1. Fairphone 3 Speaker Module Replacement, Back Cover: adım 1, 2 resimden 1. Fairphone 3 Speaker Module Replacement, Back Cover: adım 1, 2 resimden 2.
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
  2. Fairphone 3 Speaker Module Replacement: adım 2, 3 resimden 1. Fairphone 3 Speaker Module Replacement: adım 2, 3 resimden 2. Fairphone 3 Speaker Module Replacement: adım 2, 3 resimden 3.
    • Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. Fairphone 3 Speaker Module Replacement, Battery: adım 3, 2 resimden 1. Fairphone 3 Speaker Module Replacement, Battery: adım 3, 2 resimden 2.
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lever the battery up until you can get a good grip.
  4. Fairphone 3 Speaker Module Replacement: adım 4, 2 resimden 1. Fairphone 3 Speaker Module Replacement: adım 4, 2 resimden 2.
    • Lift the battery out of its recess and remove it.
  5. Fairphone 3 Speaker Module Replacement, Display Assembly: adım 5, 1 resimden 1.
    • Whenever a Phillips #00 screw is mentioned you can also unfasten it with a size #0 bit/screwdriver.
    • Remove the thirteen Phillips #00 screws (4 mm length).
  6. Fairphone 3 Speaker Module Replacement: adım 6, 3 resimden 1. Fairphone 3 Speaker Module Replacement: adım 6, 3 resimden 2. Fairphone 3 Speaker Module Replacement: adım 6, 3 resimden 3.
    • Make sure to insert the opening pick between the midframe and the display module and not into the small gap next to the screen. Otherwise you're going to pry up the screen instead of the whole display module.
    • Insert an opening pick between the midframe and the display module on the right edge of the phone.
    • Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
  7. Fairphone 3 Speaker Module Replacement: adım 7, 2 resimden 1. Fairphone 3 Speaker Module Replacement: adım 7, 2 resimden 2.
    • Slide the opening pick around the bottom right corner and use it to disengage the plastic clamps at the bottom of the display module.
  8. Fairphone 3 Speaker Module Replacement: adım 8, 2 resimden 1. Fairphone 3 Speaker Module Replacement: adım 8, 2 resimden 2.
    • Slide the opening pick along the left side to pry the display module up.
    • The display module should pop out of the midframe during this process. In case it doesn’t, check for remaining clamps you might have missed.
  9. Fairphone 3 Speaker Module Replacement: adım 9, 2 resimden 1. Fairphone 3 Speaker Module Replacement: adım 9, 2 resimden 2.
    • Remove the display assembly.
    • To reinstall the display-module press it into place on all sides until you can hear a snap from the plastic clamps to make sure it sits flush with the frame.
    • If you install a new display: The new display module comes with a white plastic cover held by 2 screws over the processor and the connectors. This needs to be taken off.
  10. Fairphone 3 Speaker Module Replacement, Bottom Module: adım 10, 1 resimden 1.
    • Remove the four 4.1mm-longPhillips #00 screws.
  11. Fairphone 3 Speaker Module Replacement: adım 11, 2 resimden 1. Fairphone 3 Speaker Module Replacement: adım 11, 2 resimden 2.
    • Use a spudger to pry up and disconnect the bottom module connecting cable.
  12. Fairphone 3 Speaker Module Replacement: adım 12, 2 resimden 1. Fairphone 3 Speaker Module Replacement: adım 12, 2 resimden 2.
    • Use your fingers to remove the bottom module.
  13. Fairphone 3 Speaker Module Replacement, Speaker Module: adım 13, 1 resimden 1.
    • Remove the 4.1mm-long Phillips #00 screw.
  14. Fairphone 3 Speaker Module Replacement: adım 14, 2 resimden 1. Fairphone 3 Speaker Module Replacement: adım 14, 2 resimden 2.
    • Use your fingers to remove the speaker module.
Sonuç
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
5 farklı kişi bu kılavuzu tamamladı.
Adriana Zwink
45.523 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
15.203 adet Kılavuz yazıldı
2 Yorum
Super einfach, danke für die tollen Bilder.
Ich hab dies nur gemacht um das Phone mal wieder von Staub zu befreien, vor allem bei den Lautsprecheröffnungen hat sich einiges angesammelt.
Fabian Gugger - Yanıt
Ein “Frühjahrsputz” ist bei diesem Gerät tatsächlich eine Option :)
Tobias Isakeit -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 27
Son 30 gün: 91
Her zaman: 3,308
