Giriş
Use this guide to replace a damaged or worn-out charging case battery in your Fairphone Fairbuds.
You can buy a replacement charging case battery from Fairphone here.
Neye ihtiyacın var
Flip your charging case upside down.
Use a Phillips screwdriver to remove the 4.5 mm‑long screw securing the outer shell.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
