Ana içeriğe geç
Flydigi Apex 5 Battery Replacement
Neye ihtiyacın var
  1. Flydigi Apex 5 Battery Replacement, Battery: adım 1, 2 resimden 1. Flydigi Apex 5 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Orient the controller so that its back is facing you.
    • Apply firm downward pressure to remove both the M3 and M4 back paddles.
    FixBot'a Sor
    Yorum Ekle
  2. Flydigi Apex 5 Battery Replacement: adım 2, 3 resimden 1. Flydigi Apex 5 Battery Replacement: adım 2, 3 resimden 2. Flydigi Apex 5 Battery Replacement: adım 2, 3 resimden 3.
    • Turn the controller over so its front faces you.
    • Remove the D-pad by firmly pulling it away from the body of the controller.
    FixBot'a Sor
    Yorum Ekle
  3. Flydigi Apex 5 Battery Replacement: adım 3, 3 resimden 1. Flydigi Apex 5 Battery Replacement: adım 3, 3 resimden 2. Flydigi Apex 5 Battery Replacement: adım 3, 3 resimden 3.
    • Remove the clear, magnetically-adhered faceplate of the controller by firmly pulling it away from the body of the controller starting from the edge of the faceplate.
    FixBot'a Sor
    Yorum Ekle
  4. Flydigi Apex 5 Battery Replacement: adım 4, 3 resimden 1. Flydigi Apex 5 Battery Replacement: adım 4, 3 resimden 2. Flydigi Apex 5 Battery Replacement: adım 4, 3 resimden 3.
    • Remove the small cover from the rear of the controller by pushing it upward.
    • Remove the two 5.8mm screws behind the battery cover using a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Flydigi Apex 5 Battery Replacement: adım 5, 2 resimden 1. Flydigi Apex 5 Battery Replacement: adım 5, 2 resimden 2.
    • Remove the six 10mm long screws from the front of the controller using a Torx T6 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. Flydigi Apex 5 Battery Replacement: adım 6, 3 resimden 1. Flydigi Apex 5 Battery Replacement: adım 6, 3 resimden 2. Flydigi Apex 5 Battery Replacement: adım 6, 3 resimden 3.
    • Insert the plastic opening tool between the top and bottom plastic controller molds, then pry until the two pieces separate.
    • Be careful not to fully separate the two pieces of the controller. There is a fragile ribbon cable connecting the two sides that must be carefully disconnected in the next step.
    FixBot'a Sor
    Yorum Ekle
  7. Flydigi Apex 5 Battery Replacement: adım 7, 3 resimden 1. Flydigi Apex 5 Battery Replacement: adım 7, 3 resimden 2. Flydigi Apex 5 Battery Replacement: adım 7, 3 resimden 3.
    • Carefully remove the back paddle ribbon cable with the angled tweezers or spudger.
    FixBot'a Sor
    Yorum Ekle
  8. Flydigi Apex 5 Battery Replacement: adım 8, 3 resimden 1. Flydigi Apex 5 Battery Replacement: adım 8, 3 resimden 2. Flydigi Apex 5 Battery Replacement: adım 8, 3 resimden 3.
    • Press a prong of each side of the angled tweezers under the lip of the power supply cable connector and pull the plastic connector out of its terminal.
    • Pull the power supply cable through the plastic cable guides.
    FixBot'a Sor
    Yorum Ekle
  9. Flydigi Apex 5 Battery Replacement: adım 9, 3 resimden 1. Flydigi Apex 5 Battery Replacement: adım 9, 3 resimden 2. Flydigi Apex 5 Battery Replacement: adım 9, 3 resimden 3.
    • Optional: Drip isopropyl alcohol along the sides of the battery. Then rotate the controller to distribute the alcohol and dissolve the adhesive holding the battery to the mount
    • Pry up the battery with the plastic hook and pry tool.
    • Do not use sharp metal tools to pry the battery out. That action risks puncturing the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Benjamin Tapp
375 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 67
Her zaman: 195
