Ana içeriğe geç
Fujifilm X-M1 Disassembly
Neye ihtiyacın var
  1. Fujifilm X-M1 Disassembly, Fujifilm X-M1 Disassembly: adım 1, 1 resimden 1.
    • If you haven't done so already, remove the lens from the camera.
    • Remove the six 2.5 mm Phillips screws from the bottom of the camera.
    FixBot'a Sor
    Yorum Ekle
  2. Fujifilm X-M1 Disassembly: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers or a finger nail to peel back the rubber cover on the left handgrip.
    • Remove the 3.4 mm Phillips screw.
    • Remove the 3.7 mm screw.
    FixBot'a Sor
    Yorum Ekle
  3. Fujifilm X-M1 Disassembly: adım 3, 1 resimden 1.
    • Use tweezers or a fingernail to peel back the rubber cover on the right handgrip.
    • Remove the 3.2 mm Phillips screw.
    • Remove the 3.8 mm Phillips screw.
    • Remove the 2.8 mm Phillips screw.
    FixBot'a Sor
    Yorum Ekle
  4. Fujifilm X-M1 Disassembly: adım 4, 3 resimden 1. Fujifilm X-M1 Disassembly: adım 4, 3 resimden 2. Fujifilm X-M1 Disassembly: adım 4, 3 resimden 3.
    • Remove the six 6.5 mm Phillips screws from the lens mount.
    • Use tweezers to remove the top metal ring and the thin metal ring below it .
    FixBot'a Sor
    Yorum Ekle
  5. Fujifilm X-M1 Disassembly: adım 5, 1 resimden 1.
    • Remove the four 4.3 mm screws securing the sensor to the front case.
    FixBot'a Sor
    Yorum Ekle
  6. Fujifilm X-M1 Disassembly: adım 6, 2 resimden 1. Fujifilm X-M1 Disassembly: adım 6, 2 resimden 2.
    • Use tweezers to slide the metal shield straight out of the external flash mount.
    FixBot'a Sor
    Yorum Ekle
  7. Fujifilm X-M1 Disassembly: adım 7, 3 resimden 1. Fujifilm X-M1 Disassembly: adım 7, 3 resimden 2. Fujifilm X-M1 Disassembly: adım 7, 3 resimden 3.
    • Remove the four 4.6 mm Phillips screws from the external flash mount.
    • Use tweezers or two fingers to remove the mount clip.
    FixBot'a Sor
    Yorum Ekle
  8. Fujifilm X-M1 Disassembly: adım 8, 1 resimden 1.
    • Extend the LCD.
    • Remove the two black 4.3 mm Phillips screws from the back case.
    FixBot'a Sor
    Yorum Ekle
  9. Fujifilm X-M1 Disassembly: adım 9, 2 resimden 1. Fujifilm X-M1 Disassembly: adım 9, 2 resimden 2.
    • Use two fingers to peel back and remove the black plastic cover from behind the LCD.
    FixBot'a Sor
    Yorum Ekle
  10. Fujifilm X-M1 Disassembly: adım 10, 3 resimden 1. Fujifilm X-M1 Disassembly: adım 10, 3 resimden 2. Fujifilm X-M1 Disassembly: adım 10, 3 resimden 3.
    • Slowly pull the back frame away from the camera.
    • Do not attempt to remove the frame, as it is attached to the camera by a ribbon cable.
    • Use tweezers to pull the white and blue ribbon cable out of the connector.
    FixBot'a Sor
    Yorum Ekle
  11. Fujifilm X-M1 Disassembly: adım 11, 1 resimden 1.
    • Slide the frame around the LCD to remove it from the camera.
    FixBot'a Sor
    Yorum Ekle
  12. Fujifilm X-M1 Disassembly: adım 12, 1 resimden 1.
    • Remove the two 2.6 mm Phillips screws from the right side of the metal frame.
    FixBot'a Sor
    Yorum Ekle
  13. Fujifilm X-M1 Disassembly: adım 13, 2 resimden 1. Fujifilm X-M1 Disassembly: adım 13, 2 resimden 2.
    • Use tweezers to unhook the speaker near the left handgrip.
    FixBot'a Sor
    Yorum Ekle
  14. Fujifilm X-M1 Disassembly: adım 14, 2 resimden 1. Fujifilm X-M1 Disassembly: adım 14, 2 resimden 2.
    • Slowly lift the metal frame away from the motherboard.
    • Do not attempt to remove the frame, as it is attached to the motherboard by a large ribbon cable.
    • Use tweezers to remove the plastic covering the motherboard.
    FixBot'a Sor
    Yorum Ekle
  15. Fujifilm X-M1 Disassembly: adım 15, 3 resimden 1. Fujifilm X-M1 Disassembly: adım 15, 3 resimden 2. Fujifilm X-M1 Disassembly: adım 15, 3 resimden 3.
    • To remove the ribbon cable, flip back the orange lock on the large ZIF connector with the flat end of a spudger.
    • If the ribbon cable does not pop out on its own, use tweezers to pull it out of the connector.
    FixBot'a Sor
    Yorum Ekle
  16. Fujifilm X-M1 Disassembly: adım 16, 1 resimden 1.
    • Use tweezers to remove the three pieces of tape covering the components of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  17. Fujifilm X-M1 Disassembly: adım 17, 3 resimden 1. Fujifilm X-M1 Disassembly: adım 17, 3 resimden 2. Fujifilm X-M1 Disassembly: adım 17, 3 resimden 3.
    • Desolder the three pairs of red and black wires attached to the mother board.
    • Learn more about desoldering wires here.
    FixBot'a Sor
    Yorum Ekle
  18. Fujifilm X-M1 Disassembly: adım 18, 2 resimden 1. Fujifilm X-M1 Disassembly: adım 18, 2 resimden 2.
    • Use tweezers to remove the grey cushion located below the flash button.
    FixBot'a Sor
    Yorum Ekle
  19. Fujifilm X-M1 Disassembly: adım 19, 3 resimden 1. Fujifilm X-M1 Disassembly: adım 19, 3 resimden 2. Fujifilm X-M1 Disassembly: adım 19, 3 resimden 3.
    • Use two fingers to remove the two ribbon cables in the bottom left corner of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  20. Fujifilm X-M1 Disassembly: adım 20, 3 resimden 1. Fujifilm X-M1 Disassembly: adım 20, 3 resimden 2. Fujifilm X-M1 Disassembly: adım 20, 3 resimden 3.
    • Use the flat end of a spudger to unlock the four indicated ZIF connectors.
    • Use two fingers to pull the ribbon cables out of the connectors.
    FixBot'a Sor
    Yorum Ekle
  21. Fujifilm X-M1 Disassembly: adım 21, 2 resimden 1. Fujifilm X-M1 Disassembly: adım 21, 2 resimden 2.
    • Remove the 3.3 mm Phillips screw from the upper left corner of the motherboard.
    • Remove the 2.4 mm Phillips screw in the bottom right corner of the motherboard.
    • Use two fingers to remove the motherboard from the front case.
    FixBot'a Sor
    Yorum Ekle
  22. Fujifilm X-M1 Disassembly: adım 22, 3 resimden 1. Fujifilm X-M1 Disassembly: adım 22, 3 resimden 2. Fujifilm X-M1 Disassembly: adım 22, 3 resimden 3.
    • Use tweezers to remove the black plastic tape at the top of the battery compartment.
    • Insert a Phillips #00 screwdriver through the hole beneath the black tape to remove a 4.8 mm screw.
    • Insert a Phillips #00 screwdriver through the white tamper evident sticker to remove a second 4.8 mm screw.
    FixBot'a Sor
    Yorum Ekle
  23. Fujifilm X-M1 Disassembly: adım 23, 1 resimden 1.
    • Remove the 3.7 mm Phillips screw from the bottom of the sensor mount.
    • Remove the 4.2 mm Phillips screw from the bottom of the sensor mount.
    • Remove the 6.2 mm Phillips screw hiding between the sensor mount and the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  24. Fujifilm X-M1 Disassembly: adım 24, 2 resimden 1. Fujifilm X-M1 Disassembly: adım 24, 2 resimden 2.
    • Press the flash button to release the flash assembly.
    • Remove the 3.4 mm Phillips screw in the back of the flash compartment.
    FixBot'a Sor
    Yorum Ekle
  25. Fujifilm X-M1 Disassembly: adım 25, 2 resimden 1. Fujifilm X-M1 Disassembly: adım 25, 2 resimden 2.
    • Remove the top plate.
    FixBot'a Sor
    Yorum Ekle
  26. Fujifilm X-M1 Disassembly: adım 26, 1 resimden 1.
    • Remove the sensor assembly.
    FixBot'a Sor
    Yorum Ekle
  27. Fujifilm X-M1 Disassembly: adım 27, 2 resimden 1. Fujifilm X-M1 Disassembly: adım 27, 2 resimden 2.
    • Remove the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  28. Fujifilm X-M1 Disassembly: adım 28, 2 resimden 1. Fujifilm X-M1 Disassembly: adım 28, 2 resimden 2.
    • Remove the four 2.6 mm Phillips screws from the LCD hinges.
    • Tilt the LCD away from the metal frame.
    • Do not attempt to remove the LCD, as it is attached to the metal frame by a ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  29. Fujifilm X-M1 Disassembly: adım 29, 2 resimden 1. Fujifilm X-M1 Disassembly: adım 29, 2 resimden 2.
    • Use two fingers to pull the ribbon through the hole in the metal frame.
    • Remove the LCD from the metal frame.
    FixBot'a Sor
    Yorum Ekle
  30. Fujifilm X-M1 Disassembly: adım 30, 2 resimden 1. Fujifilm X-M1 Disassembly: adım 30, 2 resimden 2.
    • Use the pointed end of a spudger to remove the ribbon cover on the back of the LCD.
    FixBot'a Sor
    Yorum Ekle
  31. Fujifilm X-M1 Disassembly: adım 31, 2 resimden 1. Fujifilm X-M1 Disassembly: adım 31, 2 resimden 2.
    • Remove the two 2.6 mm Phillips screws from the right hand side of the LCD screen.
    • Remove the two 2.6 mm Phillips screws from the left hand side of the LCD screen.
    FixBot'a Sor
    Yorum Ekle
  32. Fujifilm X-M1 Disassembly: adım 32, 3 resimden 1. Fujifilm X-M1 Disassembly: adım 32, 3 resimden 2. Fujifilm X-M1 Disassembly: adım 32, 3 resimden 3.
    • Use a plastic opening tool to pry the LCD case open.
    • Once the case is open, pull the ribbon through the hole on the back case.
    FixBot'a Sor
    Yorum Ekle
  33. Fujifilm X-M1 Disassembly: adım 33, 1 resimden 1.
    • Remove the LCD from the screen cover.
    FixBot'a Sor
    Yorum Ekle
  34. Fujifilm X-M1 Disassembly: adım 34, 1 resimden 1.
    • You have successfully disassembled the Fujifilm X-M1!
    FixBot'a Sor
    Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Kelsea Weber
21.457 İtibar
32 adet Kılavuz yazıldı
7Kılavuz Yorumları
what about the top plate??? no one apparently knows how to remove the rotary switches from the upper assembly. Still looking for someone to show how those things are assembled
Juan Paz - Yanıt Paylaş
Hi, I have disassembled in more detail the whole camera and collected in reverse order to every detail , I can send you my photos for a complete collection of disassembly of the camera, my email: tyapa141465@mail.ru
Felus Felus - Yanıt Paylaş
Great article.
I have disassembled mine in order to clean dust inside sensor assembly, i took apart #26 using top 2 screws and the bottom one.
Unfortuntatly in the middle there were spacers, on the bottom 3 of them, on the upper side i have found 5 little metal spacers… without knowing how many were on the left, and on the right. Do you have pictures of this stage? Tya.
Francesco - Yanıt Paylaş
Большое спасибо автору статьи. Благодаря ей разобрали Fuji X-A2 для ремонта (после падения камеры не работала часть функций). После разборки и последующей сборки камера работает как новая. Только черную пленку под LCD пришлось выбросить, потому что она одноразовая
Lena Raigorodskiy - Yanıt Paylaş
Many thanks to the author of the article. Thanks to her dismantled Fuji X-A2 for repair (after the fall of the camera did not work part of the functions). After disassembly and subsequent Assembly, the camera works as new. Only the black film under the LCD had to be thrown away, because it is disposable
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 20
Son 30 gün: 132
Her zaman: 16,249
