Ana içeriğe geç
Galaxy S20 Screen and Battery Assembly Replacement
Neye ihtiyacın var
  1. Galaxy S20 Screen and Battery Assembly Replacement, Eject the SIM tray: adım 1, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Eject the SIM tray: adım 1, 2 resimden 2.
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
    • If you inserted the tool into the other hole, don't worry—the microphone and the ingress gasket are mounted out of harm's way.
    • Press in firmly to eject the tray.
  2. Galaxy S20 Screen and Battery Assembly Replacement, Remove the SIM tray: adım 2, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Remove the SIM tray: adım 2, 2 resimden 2.
    • Remove the SIM card tray.
    • The SIM card will fall out of the tray easily.
    • When you reinsert the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your phone's internal components.
  3. Galaxy S20 Screen and Battery Assembly Replacement, Heat the bottom edge: adım 3, 1 resimden 1.
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  4. Galaxy S20 Screen and Battery Assembly Replacement, Separate the bottom edge adhesive: adım 4, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Separate the bottom edge adhesive: adım 4, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Separate the bottom edge adhesive: adım 4, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts of reheating with the iOpener and separating with the suction cup before you get it right.
    • If you are having trouble creating a gap, apply more heat to the edge and try again.
    • Do not apply excessive force with the pick, or you risk cracking the back cover glass.
  5. Galaxy S20 Screen and Battery Assembly Replacement: adım 5, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement: adım 5, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement: adım 5, 3 resimden 3.
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel.
    • Leave your opening pick in the seam to prevent the adhesive from resealing.
  6. Galaxy S20 Screen and Battery Assembly Replacement, Heat the left edge: adım 6, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  7. Galaxy S20 Screen and Battery Assembly Replacement, Separate the left edge adhesive: adım 7, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Separate the left edge adhesive: adım 7, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Separate the left edge adhesive: adım 7, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
    • As the glass on this edge is curved, you won't be able to insert this pick very far. As long as the very tip of the pick is underneath the glass's edge, you will be able to proceed.
    • Due to tight tolerances, this may take multiple attempts.
    • You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
  8. Galaxy S20 Screen and Battery Assembly Replacement: adım 8, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement: adım 8, 2 resimden 2.
    • Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
  9. Galaxy S20 Screen and Battery Assembly Replacement: adım 9, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement: adım 9, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement: adım 9, 3 resimden 3.
    • Slide the pick all along the left edge of the phone to separate the back cover's adhesive.
    • Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking.
    • Leave your pick under the left edge of the glass near the top left corner to prevent the adhesive from resealing.
  10. Galaxy S20 Screen and Battery Assembly Replacement, Heat the right edge: adım 10, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the back cover for two minutes.
  11. Galaxy S20 Screen and Battery Assembly Replacement, Separate the right edge adhesive: adım 11, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Separate the right edge adhesive: adım 11, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Separate the right edge adhesive: adım 11, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Like with the previous edge, you will need to tilt the opening pick downward to fully insert it underneath the back cover.
  12. Galaxy S20 Screen and Battery Assembly Replacement: adım 12, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement: adım 12, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement: adım 12, 3 resimden 3.
    • Slide the pick all along the right edge of the phone to separate the back cover's adhesive.
    • Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing.
    • As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
  13. Galaxy S20 Screen and Battery Assembly Replacement, Heat the top edge: adım 13, 1 resimden 1.
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  14. Galaxy S20 Screen and Battery Assembly Replacement, Separate the top edge adhesive: adım 14, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Separate the top edge adhesive: adım 14, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Separate the top edge adhesive: adım 14, 3 resimden 3.
    • The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover.
    • Gradually slide the pick from the right edge of the device around the top right corner.
    • Continue slicing along the top edge all the way to the top left corner to fully separate the back cover adhesive.
    • If the slicing becomes difficult at any point, stop and reapply heat before continuing.
  15. Galaxy S20 Screen and Battery Assembly Replacement, Remove the back cover: adım 15, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Remove the back cover: adım 15, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  16. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the wireless charging coil: adım 16, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the wireless charging coil: adım 16, 2 resimden 2.
    • Use a spudger to pry up and disconnect the wireless charging coil's press connector on the motherboard.
  17. Galaxy S20 Screen and Battery Assembly Replacement, Unfasten the motherboard bracket: adım 17, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Unfasten the motherboard bracket: adım 17, 2 resimden 2.
    Magnetic Project Mat
    $19.95
    Satın Al
    • Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the motherboard bracket.
  18. Galaxy S20 Screen and Battery Assembly Replacement, Unclip the motherboard bracket: adım 18, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Unclip the motherboard bracket: adım 18, 2 resimden 2.
    Satın Al
    • Use a pair of blunt-nose tweezers to gently pull up and unclip the motherboard bracket from the plastic midframe.
    • Do not completely remove the bracket yet, as its still attached to the wireless charging coil.
  19. Galaxy S20 Screen and Battery Assembly Replacement, Unfasten the loudspeaker: adım 19, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Unfasten the loudspeaker: adım 19, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the loudspeaker and lower midframe.
  20. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the loudspeaker: adım 20, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the loudspeaker: adım 20, 2 resimden 2.
    • Insert the point of a spudger into the notch in the top left corner of the midframe and pry up to release the clips holding it in place.
  21. Galaxy S20 Screen and Battery Assembly Replacement, Remove the wireless charging coil: adım 21, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Remove the wireless charging coil: adım 21, 2 resimden 2.
    • Remove the wireless charging coil.
  22. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the battery: adım 22, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the battery: adım 22, 2 resimden 2.
    • Use a spudger to pry up and disconnect the battery's press connector on the motherboard.
  23. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the flex cables: adım 23, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the flex cables: adım 23, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the flex cables: adım 23, 3 resimden 3.
    • Use a spudger to pry up and disconnect the primary and secondary flex cables from the motherboard.
  24. Galaxy S20 Screen and Battery Assembly Replacement: adım 24, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement: adım 24, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement: adım 24, 3 resimden 3.
    • Use a spudger to pry up and disconnect the primary and secondary flex cables from the daughterboard near the bottom of the device.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  25. Galaxy S20 Screen and Battery Assembly Replacement, Remove the flex cables: adım 25, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Remove the flex cables: adım 25, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Remove the flex cables: adım 25, 3 resimden 3.
    • Remove the primary and secondary flex cables.
    • Set the cables aside. You'll reuse them during reassembly.
  26. Galaxy S20 Screen and Battery Assembly Replacement, Unfasten the daughterboard: adım 26, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Unfasten the daughterboard: adım 26, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the three 3.4 mm-long screws securing the USB-C port and daughterboard.
  27. Galaxy S20 Screen and Battery Assembly Replacement, Remove the daughterboard: adım 27, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Remove the daughterboard: adım 27, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Remove the daughterboard: adım 27, 3 resimden 3.
    Satın Al
    • Insert the pointed end of a spudger under the left edge of the daughterboard and pry up to release it from its recess.
    • Use a pair of tweezers to pull the daughterboard up and away from the bottom of the device and remove it.
  28. Galaxy S20 Screen and Battery Assembly Replacement, Heat the vibrator: adım 28, 1 resimden 1.
    • Apply a heated iOpener to the bottom-right corner of the device for 90 seconds.
  29. Galaxy S20 Screen and Battery Assembly Replacement, Remove the vibrator: adım 29, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Remove the vibrator: adım 29, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Remove the vibrator: adım 29, 3 resimden 3.
    • Insert the tip of a spudger between the frame and the notch in the vibrator's edge, close to the bottom edge of the device.
    • Pry up with the spudger to separate the vibrator from the frame.
    • Remove the vibrator.
    • Set the vibrator aside. You'll reuse it during reassembly.
  30. Galaxy S20 Screen and Battery Assembly Replacement, Vibrator reassembly instructions: adım 30, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Vibrator reassembly instructions: adım 30, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Vibrator reassembly instructions: adım 30, 3 resimden 3.
    Satın Al
    • During reassembly, follow these instructions to reinstall your vibrator:
    • Peel off the vibrator adhesive from its liner and apply the sticky end to the frame.
    • Use tweezers, or your fingers, to pull on the tab and expose the top layer of adhesive.
    • Insert the vibrator and apply pressure to adhere it to the frame.
  31. Galaxy S20 Screen and Battery Assembly Replacement, Unfasten the upper midframe: adım 31, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Unfasten the upper midframe: adım 31, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the four 4 mm-long screws securing the upper midframe.
  32. Galaxy S20 Screen and Battery Assembly Replacement, Remove the upper midframe: adım 32, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Remove the upper midframe: adım 32, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Remove the upper midframe: adım 32, 3 resimden 3.
    • Insert the point of a spudger into the notch on the right side of the upper midframe and pry up to release the clips holding it into place.
    • Remove the upper midframe.
  33. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the left cables: adım 33, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the left cables: adım 33, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the left cables: adım 33, 3 resimden 3.
    • Use a spudger to pry up and disconnect the left 5G mmWave antenna's press connector from the motherboard.
    • Repeat for the power button cable.
  34. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the front camera: adım 34, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the front camera: adım 34, 2 resimden 2.
    • Pry up and disconnect the front facing camera flex cable from the motherboard.
    • Bend the cable out of the way of the motherboard.
  35. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the proximity sensor: adım 35, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the proximity sensor: adım 35, 2 resimden 2.
    • Pry up and disconnect the proximity sensor cable from the motherboard.
  36. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the right 5G mmWave antenna: adım 36, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the right 5G mmWave antenna: adım 36, 2 resimden 2.
    • Use a spudger to pry up and disconnect the right 5G mmWave antenna's press connector.
  37. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the main display cable: adım 37, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Disconnect the main display cable: adım 37, 2 resimden 2.
    • Use a spudger to pry up and disconnect the main display flex cable from the motherboard.
  38. Galaxy S20 Screen and Battery Assembly Replacement, Reposition the display cable: adım 38, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Reposition the display cable: adım 38, 2 resimden 2.
    • Gently peel up and bend the display flex cable out of the way of the motherboard and battery.
  39. Galaxy S20 Screen and Battery Assembly Replacement, Reposition the left 5G cable: adım 39, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Reposition the left 5G cable: adım 39, 2 resimden 2.
    • Use tweezers, or your fingers, to gently peel the left 5G cable away from the device.
  40. Galaxy S20 Screen and Battery Assembly Replacement, Unfasten the motherboard assembly: adım 40, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Unfasten the motherboard assembly: adım 40, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two screws securing the motherboard and camera assembly:
    • One 4 mm-long screw
    • One 3 mm-long screw
  41. Galaxy S20 Screen and Battery Assembly Replacement, Remove the motherboard assembly: adım 41, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Remove the motherboard assembly: adım 41, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Remove the motherboard assembly: adım 41, 3 resimden 3.
    • Insert the flat end of a spudger into the bottom left corner of the motherboard assembly and pry up to release it from the phone body.
    • Remove the motherboard assembly.
  42. Galaxy S20 Screen and Battery Assembly Replacement, Heat the front camera: adım 42, 1 resimden 1.
    • Apply a heated iOpener to the front camera for 90 seconds.
  43. Galaxy S20 Screen and Battery Assembly Replacement, Remove the front camera: adım 43, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Remove the front camera: adım 43, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Remove the front camera: adım 43, 3 resimden 3.
    • Insert a spudger into the gap between the frame and the front camera.
    • Pry up with the spudger to separate the front camera from the frame.
    • If you're having trouble separating the front camera from the frame, apply more heat.
    • Use tweezers, or your fingers, to remove the front camera.
    • Set the camera aside. You'll reuse it during reassembly.
  44. Galaxy S20 Screen and Battery Assembly Replacement, Front camera reassembly instructions: adım 44, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Front camera reassembly instructions: adım 44, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Front camera reassembly instructions: adım 44, 3 resimden 3.
    • During reassembly, follow these instructions to reinstall your front camera:
    • Peel off the front camera adhesive from its liner and apply the sticky end to the frame.
    • Insert the front camera and apply pressure to adhere it to the frame.
  45. Galaxy S20 Screen and Battery Assembly Replacement, Unfasten the 5G mmWave antennas: adım 45, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Unfasten the 5G mmWave antennas: adım 45, 2 resimden 2.
    • Use a Phillips screwdriver to remove the three 3.4 mm-long screws securing the 5G mmWave antennas.
  46. Galaxy S20 Screen and Battery Assembly Replacement, Remove the right 5G mmWave antenna: adım 46, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Remove the right 5G mmWave antenna: adım 46, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Remove the right 5G mmWave antenna: adım 46, 3 resimden 3.
    • Use the point of a spudger to pry up on the 5G mmWave antenna bracket's bottom screw tab.
    • Use tweezers, or your fingers, to remove the 5G mmWave antenna.
    • Set the antenna aside. You'll reuse it during reassembly.
  47. Galaxy S20 Screen and Battery Assembly Replacement, Remove the left 5G mmWave antenna: adım 47, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Remove the left 5G mmWave antenna: adım 47, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Remove the left 5G mmWave antenna: adım 47, 3 resimden 3.
    • Use the point of a spudger to pry up on the 5G mmWave antenna bracket's top edge.
  48. Galaxy S20 Screen and Battery Assembly Replacement, Heat the proximity sensor: adım 48, 1 resimden 1.
  49. Galaxy S20 Screen and Battery Assembly Replacement, Remove the proximity sensor: adım 49, 3 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement, Remove the proximity sensor: adım 49, 3 resimden 2. Galaxy S20 Screen and Battery Assembly Replacement, Remove the proximity sensor: adım 49, 3 resimden 3.
    • Insert an opening pick between the bottom of the proximity sensor and the frame.
    • Slide the pick towards the top of the phone to separate the proximity sensor adhesive.
  50. Galaxy S20 Screen and Battery Assembly Replacement: adım 50, 2 resimden 1. Galaxy S20 Screen and Battery Assembly Replacement: adım 50, 2 resimden 2.
    • Remove the proximity sensor.
    • Set the sensor aside. You'll reuse it during reassembly.
    • If the original adhesive is deformed, remove it and apply new precut adhesive—otherwise your proximity sensor won't sit properly in its recess.
  51. Galaxy S20 Screen and Battery Assembly Replacement, Only the screen and battery assembly remains: adım 51, 1 resimden 1.
    • You're now left with the screen and battery assembly.
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
129.318 İtibar
600 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.077 adet Kılavuz yazıldı
5 Yorum
There were a few minor differences with my disassembly I wanted to note in case other users run into the same thing:
Note: The biggest curve ball for me was that the guide does not discuss how to remove the proximity sensor from the old assembly and move it to the new one. I winged it, but hopefully iFIXIT will update this guide, and also provide new adhesive for the sensor, because this is absolutely a necessary step to make.
Step 16: It was not necessary to disconnect the wireless charging coil. There was no fastened connection, just contact.
Step 31: The location of the screws for the upper midframe is slightly different on my model. The second from the right screw is closer to the middle.
Step 33: There was only one cable coming from the left frame. There was no 5G cable
Step 36: not present
Step 42-44: The replacement assembly includes the front camera
Step 45-47: Not applicable
Corey Walters - Yanıt
Everything went well replacing the display and battery. The most difficult part was that there was not mention of the proximity sensor from the old assembly and just had to figure it out myself. Heated it up to remove but had to use the old adhesive. Also, should have purchased a new back cover because getting the old adhesive off was not easy. Phone now works like new.
Robert Stanley - Yanıt
I left a few comments on steps within the guide that should help any slight variations during the procedure. In the conclusion, there is a repair app that is supposed to allow you to calibrate the new hardware, but I wasn't able to open the app, and my kit didn't come with the tools for calibrating the fingerprint sensor anyways. This doesn't seem to be a absolutely necessary though; the battery is auto-calibrating with full charge and drain cycles, the new fingerprint reader still works perfectly with my original fingerprints, and the front camera is fully functional. Additionally, all tests in the Samsung Members app passed, so everything seems to be 100% functional.
Ryan Sammons - Yanıt
The reason for reading this was for the battery replacement and going through the whole thing I read the last instruction, "You're now left with the screen and battery assembly"... Am I missing something? (I read through, luckily did not actually do the steps).
Schuyler Schultz - Yanıt
Yes, the guide ended without steps for the Battery and screen replacement! WTF?
R S - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 42
Son 30 gün: 212
Her zaman: 13,029
