Ana içeriğe geç
Garmin Dezl 760LMT Screen Replacement
Ryan Williams
Ryan Williams ve 4 diğer katkıda bulunanlar
En son December 14, 2016 tarihinde güncellendi
10 dakika
Orta
This guide will show you how to properly and safely remove the Garmin Dezl 760LMT's screen from the motherboard and its casing.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Garmin Dezl 760LMT Screen Replacement, Back Panel: adım 1, 2 resimden 1. Garmin Dezl 760LMT Screen Replacement, Back Panel: adım 1, 2 resimden 2.
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Screen Replacement: adım 2, 3 resimden 1. Garmin Dezl 760LMT Screen Replacement: adım 2, 3 resimden 2. Garmin Dezl 760LMT Screen Replacement: adım 2, 3 resimden 3.
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Screen Replacement: adım 3, 1 resimden 1.
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Screen Replacement, Screen Ribbon Cable: adım 4, 2 resimden 1. Garmin Dezl 760LMT Screen Replacement, Screen Ribbon Cable: adım 4, 2 resimden 2.
    • Lift the screen opposite where the "GARMIN" logo is located. Remove the clear tape holding the ribbon cable to the motherboard.
  5. Garmin Dezl 760LMT Screen Replacement: adım 5, 2 resimden 1. Garmin Dezl 760LMT Screen Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Find and lift the small grey hinge at the end of the ribbon cable.
    • When handling the motherboard, make sure to wear an anti-static wrist strap.
  6. Garmin Dezl 760LMT Screen Replacement, Screen: adım 6, 2 resimden 1. Garmin Dezl 760LMT Screen Replacement, Screen: adım 6, 2 resimden 2.
    • Using a Torx T5 screwdriver, unscrew the four 7mm screws from the back plate of the screen.
  7. Garmin Dezl 760LMT Screen Replacement: adım 7, 3 resimden 1. Garmin Dezl 760LMT Screen Replacement: adım 7, 3 resimden 2. Garmin Dezl 760LMT Screen Replacement: adım 7, 3 resimden 3.
    • Turn the screen over so that it is facing upwards.
    • Remove the front plate of the screen.
    • Lift the screen from its back casing.
Sonuç
Ryan Williams
763 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-2, Passmore Fall 2016 USF Tampa, Team 4-2, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S4G2
4 Üyeler
2 Yorum
where can one by the replacement screen
tempestrogue - Yanıt
Ebay sells these screens replacement - search online for “ZD070NA-03K “ or on google, even amazon sometimes has them. Its a hard to find screen so you will probably only get it from hong kong or china.
neilneves - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 2,489
