Ana içeriğe geç
Garmin Drive 52 and Traffic Motherboard Replacement
Jason Wilson
Jason Wilson ve 5 diğer katkıda bulunanlar
En son January 10, 2025 tarihinde güncellendi
35 - 45 dakika
Orta
This guide helps you to replace the motherboard of the Garmin Drive 52 & Traffic GPS.
The motherboard is the central hub of your GPS device, responsible for connecting and powering all its internal components. Over time, damage or wear can cause symptoms like unresponsiveness, persistent error messages, or total device failure.
Always disconnect the device from any power source and ensure it is powered down before you begin.
Neye ihtiyacın var
Aletler
  1. Garmin Drive 52 and Traffic Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Garmin Drive 52 and Traffic Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Garmin Drive 52 and Traffic Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Pop the suction cup off of the device.
    • Unscrew the four T5 Torx screws on the back.
    • Carefully pry apart the front and back with a Jimmy.
  2. Garmin Drive 52 and Traffic Motherboard Replacement: adım 2, 1 resimden 1.
    • With the top in hand, carefully apply pressure on the top of the screen to pop it out of the front of the case.
  3. Garmin Drive 52 and Traffic Motherboard Replacement: adım 3, 2 resimden 1. Garmin Drive 52 and Traffic Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the four Torx T5 screws.
    • Unplug the two connectors from the motherboard and lift it up and out.
Sonuç
Jason Wilson
388 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Petersen Fall 2022 UMass Dartmouth, Team 1-2, Petersen Fall 2022 üyesi
UMASSD-PETERSEN-F22S1G2
6 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 232
