Ana içeriğe geç
Garmin DriveSmart 55 EX Battery Replacement
Neye ihtiyacın var
  1. Garmin DriveSmart 55 EX Battery Replacement, Battery: adım 1, 3 resimden 1. Garmin DriveSmart 55 EX Battery Replacement, Battery: adım 1, 3 resimden 2. Garmin DriveSmart 55 EX Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Use a T5 Torx screwdriver to remove the four 4.2 mm black screws from the back case.
    • Insert the plastic opening tool into the gap between the screen and case, and release the clips along the edges of the device.
    • Use opening picks along the perimeter to keep them separated until you can remove the screen.
    FixBot'a Sor
    Yorum Ekle
  2. Garmin DriveSmart 55 EX Battery Replacement: adım 2, 3 resimden 1. Garmin DriveSmart 55 EX Battery Replacement: adım 2, 3 resimden 2. Garmin DriveSmart 55 EX Battery Replacement: adım 2, 3 resimden 3.
    • Gently separate the screen from the case and place the device flat on the surface.
    • Avoid pulling on the screen too forcefully, as the display ribbon cable is still connected to the motherboard.
    • Use a T5 Torx screwdriver to remove the four 3.8 mm silver screws from the motherboard.
    • Avoid scratching the motherboard when using the screwdriver, as this can damage the device.
    • Gently pry the motherboard up using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  3. Garmin DriveSmart 55 EX Battery Replacement: adım 3, 3 resimden 1. Garmin DriveSmart 55 EX Battery Replacement: adım 3, 3 resimden 2. Garmin DriveSmart 55 EX Battery Replacement: adım 3, 3 resimden 3.
    • Use your fingers or tweezers to disconnect the battery connector on the underside of the motherboard.
    • Avoid pulling on the cables.
    • Gently remove the battery from the casing.
    • If you're unable to get a grip on it, use the opening tool to lift it enough to get your fingers underneath.
    • Avoid bending or puncturing the battery as it can catch fire.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 37
Her zaman: 171
