Ana içeriğe geç
Garmin DriveSmart 55 EX Motherboard Replacement
Neye ihtiyacın var
  1. Garmin DriveSmart 55 EX Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Garmin DriveSmart 55 EX Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Garmin DriveSmart 55 EX Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Use a T5 Torx screwdriver to remove the four 4.2 mm black screws from the back case.
    • Insert the plastic opening tool into the gap between the screen and case, and release the clips along the edges of the device.
    • Use opening picks along the perimeter to keep them separated until you can remove the screen.
    FixBot'a Sor
    Yorum Ekle
  2. Garmin DriveSmart 55 EX Motherboard Replacement: adım 2, 3 resimden 1. Garmin DriveSmart 55 EX Motherboard Replacement: adım 2, 3 resimden 2. Garmin DriveSmart 55 EX Motherboard Replacement: adım 2, 3 resimden 3.
    • Gently separate the screen from the case and place the device flat on the surface.
    • Avoid pulling on the screen too forcefully, as the display ribbon cable is still connected to the motherboard.
    • Use a T5 Torx screwdriver to remove the four 3.8 mm silver screws from the motherboard.
    • Avoid scratching the motherboard when using the screwdriver, as this can damage the device.
    • Gently pry the motherboard up using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  3. Garmin DriveSmart 55 EX Motherboard Replacement: adım 3, 2 resimden 1. Garmin DriveSmart 55 EX Motherboard Replacement: adım 3, 2 resimden 2.
    • Use your fingers or tweezers to disconnect the battery connector on the underside of the motherboard.
    • Avoid pulling on the cables.
    FixBot'a Sor
    Yorum Ekle
  4. Garmin DriveSmart 55 EX Motherboard Replacement: adım 4, 2 resimden 1. Garmin DriveSmart 55 EX Motherboard Replacement: adım 4, 2 resimden 2.
    • Desolder the three solder points with a soldering iron to disconnect the wires from the motherboard.
    • Be careful when using the soldering iron, the tip is hot to the touch and can damage the motherboard or other surfaces when held or placed on them.
    FixBot'a Sor
    Yorum Ekle
  5. Garmin DriveSmart 55 EX Motherboard Replacement: adım 5, 3 resimden 1. Garmin DriveSmart 55 EX Motherboard Replacement: adım 5, 3 resimden 2. Garmin DriveSmart 55 EX Motherboard Replacement: adım 5, 3 resimden 3.
    • Use a spudger or a clean fingernail to flip up the locking flap on the ZIF connector.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers to gently pull the gold ribbon cable from the socket on the motherboard.
    • Be careful when removing the ribbon cable because it is thin and can tear easily.
    • Remove the screen.
    FixBot'a Sor
    Yorum Ekle
  6. Garmin DriveSmart 55 EX Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the motherboard from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 102
