Ana içeriğe geç
Garmin Edge 830 Back Cover Replacement
Alden Gibbs
Alden Gibbs ve 3 diğer katkıda bulunanlar
En son June 26, 2024 tarihinde güncellendi
1 saat
Orta
Daha Fazla Görsel Gerekli
Eksik Adımlar
If you find yourself on this guide, it means that you are having problems attaching your Garmin Edge 830 to its respective mount. The best solution to this is to replace the back cover . In order to do this you will have to take the device apart in its entirety. This may sound like a lot of work, but we have attached all the required steps that will have you done in a timely manner. Make sure you keep track of all your parts/screws along the way.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Garmin Edge 830 Back Cover Replacement, Touch Display: adım 1, 1 resimden 1.
    • Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
    • Repeat this process a second to ensure that the glue is becoming loose.
    • Alternative: Use a heat gun or hair dryer to heat up the glue
    I have a 820 is the same process used?
    Gary Roy Hogg - Yanıt
  2. Garmin Edge 830 Back Cover Replacement: adım 2, 1 resimden 1.
    • Use the Jimmy tool carve around the edges of the screen to break the glue seal.
    Does the glue have to be replaced? If so what type of glue?
  3. Garmin Edge 830 Back Cover Replacement: adım 3, 1 resimden 1.
    • Use the iFixit plastic opening tool to pry open the screen.
  4. Garmin Edge 830 Back Cover Replacement, Motherboard: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    $3.99
    • Remove brown copper tape with the FPC (not clipped). Removing of the copper tape is necessary, I didn't find a way to avoid it. Try to remove the copper tape as gentle as possible to reuse it.
    • Also remove green tape with angled tweezers and unclip in a 2nd step the FPC from the board
  5. Garmin Edge 830 Back Cover Replacement: adım 5, 1 resimden 1.
    • Unscrew the three 1 mm screws around the perimeter of the motherboard
    • with the 2nd screw also the light senor will come of the PCB
  6. Garmin Edge 830 Back Cover Replacement: adım 6, 1 resimden 1.
    • Use the reverse tweezers to gently pull on the silver box on top of the motherboard to remove it from the back cover.
    • Alternative: Use a plastic card in between PCB and cover.
  7. Garmin Edge 830 Back Cover Replacement: adım 7, 2 resimden 1. Garmin Edge 830 Back Cover Replacement: adım 7, 2 resimden 2.
    • Locate the wire connector on the motherboard. Slowly release the wires by gently pulling with the blunt tweezers.
  8. Garmin Edge 830 Back Cover Replacement, Battery: adım 8, 1 resimden 1.
    • Use the halberd spudger to lift and remove the battery from the back cover.
  9. Garmin Edge 830 Back Cover Replacement, Back Cover: adım 9, 1 resimden 1.
    • Once all previous steps are completed, you will be left with the back cover.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alden Gibbs
265 İtibar
3 adet Kılavuz yazıldı
1Rehber Yorum
What are the steps required to put the screen back on? What glue should we use and how?
Odhita Kamayana - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 23
Son 30 gün: 88
Her zaman: 1,518
