Ana içeriğe geç
Garmin Edge 830 Battery Replacement
Alden Gibbs
Alden Gibbs ve 3 diğer katkıda bulunanlar
En son June 24, 2024 tarihinde güncellendi
1 saat
Orta
Daha Fazla Görsel Gerekli
Eksik Adımlar
If you find yourself on this guide, it means your battery is draining too quickly. In that case, it might be time to replace your battery. It is important to note that for this step you must remove the touch display and motherboard in order to access the battery. Therefore, the steps for this guide begin with taking off the touch screen followed by the motherboard.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Garmin Edge 830 Battery Replacement, Touch Display: adım 1, 1 resimden 1.
    • Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
    • Repeat this process a second to ensure that the glue is becoming loose.
    • Alternative: Use a heat gun or hair dryer to heat up the glue
    I have a 820 is the same process used?
    Gary Roy Hogg - Yanıt
  2. Garmin Edge 830 Battery Replacement: adım 2, 1 resimden 1.
    • Use the Jimmy tool carve around the edges of the screen to break the glue seal.
    Does the glue have to be replaced? If so what type of glue?
  3. Garmin Edge 830 Battery Replacement: adım 3, 1 resimden 1.
    • Use the iFixit plastic opening tool to pry open the screen.
  4. Garmin Edge 830 Battery Replacement, Motherboard: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    $3.99
    • Remove brown copper tape with the FPC (not clipped). Removing of the copper tape is necessary, I didn't find a way to avoid it. Try to remove the copper tape as gentle as possible to reuse it.
    • Also remove green tape with angled tweezers and unclip in a 2nd step the FPC from the board
  5. Garmin Edge 830 Battery Replacement: adım 5, 1 resimden 1.
    • Unscrew the three 1 mm screws around the perimeter of the motherboard
    • with the 2nd screw also the light senor will come of the PCB
  6. Garmin Edge 830 Battery Replacement: adım 6, 1 resimden 1.
    • Use the reverse tweezers to gently pull on the silver box on top of the motherboard to remove it from the back cover.
    • Alternative: Use a plastic card in between PCB and cover.
  7. Garmin Edge 830 Battery Replacement: adım 7, 2 resimden 1. Garmin Edge 830 Battery Replacement: adım 7, 2 resimden 2.
    • Locate the wire connector on the motherboard. Slowly release the wires by gently pulling with the blunt tweezers.
  8. Garmin Edge 830 Battery Replacement, Battery: adım 8, 1 resimden 1.
    • Use the halberd spudger to lift and remove the battery from the back cover.
Sonuç
Alden Gibbs
265 İtibar
3 adet Kılavuz yazıldı
3Kılavuz Yorumları
I have a Garmin 820. I've seen a video by NewLife2OldStuff on YouTube and they don't heat the seal. But I've tried their method and cant get the opening tool in the groove.
Is the removal of the screen on the 830 the same for the 820? It looks similar.
ciao ... puoi indicare le spegifiche giuste della batteria per garmin edge 830?
hi...can you give the correct battery specifications for garmin edge 830?
grazie
giancarlodilorenzo@gmail.com
gianca - Yanıt
I would like to replace the battery and therefore I am looking for a compatible model
gianca - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 72
Son 30 gün: 333
Her zaman: 7,994
