Garmin Edge 830 USB Port Replacement
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
Repeat this process a second to ensure that the glue is becoming loose.
Alternative: Use a heat gun or hair dryer to heat up the glue
Bu adımda kullanılan alet:Tweezers$3.99
Remove brown copper tape with the FPC (not clipped). Removing of the copper tape is necessary, I didn't find a way to avoid it. Try to remove the copper tape as gentle as possible to reuse it.
Also remove green tape with angled tweezers and unclip in a 2nd step the FPC from the board
With the T4 screwdriver, unscrew the two 1 mm screws on the green piece located on the inside of the cable connector
