Ana içeriğe geç
Garmin Nuvi 1390LMT Logic Board Replacement
Trey Ulsh
Trey Ulsh ve başka bir katkıda bulunan
En son December 24, 2015 tarihinde güncellendi
15 - 35 dakika
Orta
This guide will show you how to disassemble the Garmin Nuvi 1390LMT GPS to replace the logic board.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Garmin Nuvi 1390LMT Logic Board Replacement, Logic Board: adım 1, 1 resimden 1.
    • Snap the plastic cover off using a plastic opening tool.
  2. Garmin Nuvi 1390LMT Logic Board Replacement: adım 2, 2 resimden 1. Garmin Nuvi 1390LMT Logic Board Replacement: adım 2, 2 resimden 2.
    • Remove the four black 11 mm T5 torx screws.
  3. Garmin Nuvi 1390LMT Logic Board Replacement: adım 3, 1 resimden 1.
    • Pop the screen cover off with a plastic opening tool.
  4. Garmin Nuvi 1390LMT Logic Board Replacement: adım 4, 1 resimden 1.
    • Gently pull the wire ribbon connecting the screen to the logic board from the plug.
    • Be careful when unplugging the wire ribbon. It is very fragile.
  5. Garmin Nuvi 1390LMT Logic Board Replacement: adım 5, 1 resimden 1.
    • Remove the two silver 5 mm T5 torx screws connecting the circuit board to the plastic casing.
  6. Garmin Nuvi 1390LMT Logic Board Replacement: adım 6, 1 resimden 1.
    • Flip the logic board over.
  7. Garmin Nuvi 1390LMT Logic Board Replacement: adım 7, 2 resimden 1. Garmin Nuvi 1390LMT Logic Board Replacement: adım 7, 2 resimden 2.
    • Disconnect the harness between the battery and the logic board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Trey Ulsh
537 İtibar
3 adet Kılavuz yazıldı
Ekip
Montana Tech, Team 10-4, Shirk Fall 2015 Montana Tech, Team 10-4, Shirk Fall 2015 üyesi
MTUM-SHIRK-F15S10G4
5 Üyeler
1Rehber Yorum
I need a replacement board for My Garmin Nuvi 1490LMT - where can I get one?
Danny - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 988
