Ana içeriğe geç
Garmin Nuvi 2595LMT LCD Screen Replacement
Taylor DeWitt
Taylor DeWitt ve 3 diğer katkıda bulunanlar
En son March 30, 2016 tarihinde güncellendi
Tahmin yok
Orta
Use this guide to replace the LCD Screen of your Garmin Nuvi 2595LMT GPS.
Neye ihtiyacın var
Parçalar
Aletler
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • Spudger
    Spudger
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Garmin Nuvi 2595LMT LCD Screen Replacement, Garmin Nuvi 2595LMT Back Cover Replacement: adım 1, 1 resimden 1.
    • Place the device on the workspace so the screen is facing downward.
  2. Garmin Nuvi 2595LMT LCD Screen Replacement: adım 2, 2 resimden 1. Garmin Nuvi 2595LMT LCD Screen Replacement: adım 2, 2 resimden 2.
    • Using the t5 screwdriver from the iFixit Pro Tool Kit, remove all four 5.6mm screws placing them safely on the table.
  3. Garmin Nuvi 2595LMT LCD Screen Replacement: adım 3, 3 resimden 1. Garmin Nuvi 2595LMT LCD Screen Replacement: adım 3, 3 resimden 2. Garmin Nuvi 2595LMT LCD Screen Replacement: adım 3, 3 resimden 3.
    • Grab a spudger from tool kit.
    • Pry open sides of Nuvi gently with spudger (do not rip apart).
    • Use plastic opening tool to pry ribbon slowly from white plastic bar.
    • Separate the two pieces and place them on the table
  4. Garmin Nuvi 2595LMT LCD Screen Replacement, LCD Screen: adım 4, 2 resimden 1. Garmin Nuvi 2595LMT LCD Screen Replacement, LCD Screen: adım 4, 2 resimden 2.
    • Grabbing the top half of the Nuvi, remove the screen from the tabs holding it in place using thumbs.
    • Place screen on table.
  5. Garmin Nuvi 2595LMT LCD Screen Replacement: adım 5, 2 resimden 1. Garmin Nuvi 2595LMT LCD Screen Replacement: adım 5, 2 resimden 2.
    • Place new screen in proper position, with the ribbon facing downward.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
3 Yorum
cannot prise open the connector to replace ribbon
norman bayne - Yanıt
My screen is cracked. The screen opens, but I can't use the key board.
Thank You For any Help You Can Give Me,
Cookie
cookiecaafato1@yahoo.com nuvi 2595 LMT
cookiecalafato1 - Yanıt
Re-seating the ribbon is simply impossible.
daBee - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 4,670
