Garmin Nuvi 2797LMT LCD Screen Replacement
Giriş
1. adıma gitThis guide will show you, in easy-to-follow steps, how to replace the LCD Screen. It seems like a lot of work, but don't worry because it isn't.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
Using your T-4 Torx Screwdriver, unscrew the four 2.38 mm Torx T-4 screws from the back of your screen.
Now remove the front casing and back casing away from the screen. You will end up with three separate pieces.
i have a blank screen wondering if i didnt put the ribbon on correctly ive put it together a couple times same result hear a beep when first plugged in like normal but no screen any suggestions
4 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Instructions lacking. Go here, https://www.youtube.com/watch?v=iMotyMvC... . Not the exact same Garmin, but virtually the same and worked much better than the instructions here!!
Still can't get my older Garmin back in working order.
where can i take it for someone else to re-cycle it as I have a brand new one .
