Ana içeriğe geç
Garmin Nuvi 370 Microphone Replacement
Matt West
Matt West ve 5 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
Tahmin yok
Orta
Eşleşmeyen Ön Koşullar
Dilim ve Zar
Adım Kırpıcı
In this guide the repairer replaces the microphone by disassembling the device to access the motherboard.
Prerequisite Guide:
Disassembling Garmin Nuvi 370 Into Core Components
Tools Used:
  • Fine Point Tweezers
  • Spudger
Estimated Duration: 10 minutes
Neye ihtiyacın var
Aletler
  1. Garmin Nuvi 370 Microphone Replacement, Microphone: adım 1, 1 resimden 1.
    • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  2. Garmin Nuvi 370 Microphone Replacement: adım 2, 2 resimden 1. Garmin Nuvi 370 Microphone Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
  3. Garmin Nuvi 370 Microphone Replacement: adım 3, 2 resimden 1. Garmin Nuvi 370 Microphone Replacement: adım 3, 2 resimden 2.
    • The motherboard will now freely separate from the back casing; lay it flat next to the housing.
  4. Garmin Nuvi 370 Microphone Replacement: adım 4, 2 resimden 1. Garmin Nuvi 370 Microphone Replacement: adım 4, 2 resimden 2.
    • Disconnect the speaker and battery from their terminals on the motherboard. This should disconnect the motherboard completely from the back panel.
    • This step is optional but is recommended as it will create more room to work.
    • It is recommended that you use tweezers or the spudger for precision.
  5. Garmin Nuvi 370 Microphone Replacement: adım 5, 1 resimden 1.
    • Gently pull out the microphone wire from the terminal. Tweezers are recommended for precision.
  6. Garmin Nuvi 370 Microphone Replacement: adım 6, 1 resimden 1.
    • The microphone component should now be completely separated from the motherboard.
    • Plug in new, functional microphone component.
Bitiş Çizgisi
Matt West
31 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-65, Johann Spring 2013 Cal Poly, Team 13-65, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S13G65
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 428
