Ana içeriğe geç
Garmin Nuvi 50LM Power Button Replacement
Maurice Thomas
Maurice Thomas ve 2 diğer katkıda bulunanlar
En son December 22, 2015 tarihinde güncellendi
10 dakika
Çok kolay
There are times when the power button might fall off the device. If that happens, refer to this guide in order to replace it.
Neye ihtiyacın var
Aletler
  1. Garmin Nuvi 50LM Power Button Replacement, Power Button Replacement: adım 1, 2 resimden 1. Garmin Nuvi 50LM Power Button Replacement, Power Button Replacement: adım 1, 2 resimden 2.
    • Use the T-4 screwdriver to unscrew the 9 mm screws on the back of the device.
  2. Garmin Nuvi 50LM Power Button Replacement: adım 2, 2 resimden 1. Garmin Nuvi 50LM Power Button Replacement: adım 2, 2 resimden 2.
    • Pry open the device from all four sides using the iFixit Plastic Opening Tool until you see the inside of the system.
  3. Garmin Nuvi 50LM Power Button Replacement: adım 3, 2 resimden 1. Garmin Nuvi 50LM Power Button Replacement: adım 3, 2 resimden 2.
    • Look for a small button on the motherboard at the top of the device, and insert replacement power button on top of the small button on the motherboard until you hear a click.
    Hi, my mom has a Garmin Nuvi 50lm and it’s missing a power button! Is there a way to order a new one? It’s for a Garmin Nuvi 50lm.
    Jonas F - Yanıt
    Great question, I have same problem. Lots of advice on how to replace it but no-0ne can tell me where to get a replacement power switch. Just wondering if you've had any luck.....CHEERS
    David Hammond - Yanıt
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Maurice Thomas
664 İtibar
5 adet Kılavuz yazıldı
Ekip
3 Yorum
Does not help me a bit. My button fell off and I did not see it come off, so it is lost. Cannot fix it without info of where to get a replacement!
Denny Manning - Yanıt
The power button on my Garmin 50 LM fell off the other day. I can’t find anywhere where I can buy a new replacement. Any suggestions would be much appreciated. Thank you!
Mary - Yanıt
I’m looking for same switch part for nuvi 40lm. Unless we purchase a whole
Unit from EBay that doesn’t work just for the switch. Good luck if you find one.
Erik Pistek - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 7,029
