Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Before you begin disassembling the device, be sure the power is off. For this guide you will need to know how to use a soldering iron. For help with soldering look at this guide.
Neye ihtiyacın var
Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
Pry the outer frame off the perimeter of the rear panel assembly.
Remove the two #00 Phillips screws securing the battery to the rear case assembly.
